Results 1 to 2 of 2
Thread: 1985 200x transmission bearings question
    Oct 2016
    New York
    118
    When i took apart my transmission i found that every bushing that was inside the gear was freely spinning inside. Is this normal or are all my bushings worn out, should the bushings be a tight fit in the gear and only rotate on the shaft?
    Thanks,
    Andrew
    Jan 2014
    Massachusetts USA
    782
    They should only spin on the shaft. I found one like that in my trans, which is one of the reasons I ended up building a Franken-tranny out of 3. I think you can still get some of those bushings from Honda.
    1985 Tri-Z 250
    1985 ATC250R
