I bought the 3wheeler a few weeks ago and noticed the clutch slipping. I checked the cable adjustment and it was good. So I buy a clutch kit that contains steel plates, friction plates, and Springs. This isn't my first clutch job, and I have the Honda service manual to guide me as well. After installing new kit and everything is back together, the clutch cable is way too slack. And when it is adjusted to pull in the clutch, it isn't in far enough. I place it in first gear and pull the clutch in but it's still engaged. Any thoughts? I have pulled clutch back off and noticed that the outer clutch and plates has about 3mm of movement. I'm clue less now.
Sent from my SM-G930V using Tapatalk
