Waste of time time running a stock main jet with a Supertrapp unless it only has 1 disc in it . I would check the float level and try a 45 pilot before changing anything else . Also, if the carb is a Honda carb instead of a Chinese one, I would only use Honda jets because there can be a difference in flow between the same number size from different mfg's.
Also, make sure the plug is the correct heat range and gap.
PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
AND OWNER OF A TRI Z THAT ACTUALLY HAS A REAR SHOCK ON IT
