Page 14 of 20 FirstFirst ... 4 12 13 14 15 16 ... LastLast
Results 196 to 210 of 287
Thread: Time to see what all the Tecate hype is about?
  1. #196
    Williamstown PA
    5,826
    The master cylinder should have enough back sprig pressure to return the brake pedal. I do not run any springs on any of my machines.
  2. #197
    Las Vegas, NV.
    2,540
    Hmmm, interesting. I never really thought about it before this post, but you're right. The front brake system has no lever return spring.
  3. #198
    Apr 2019
    Greece
    58
    Yes if you think it that way (front brake)BUT we are talking about a specific machine,the KXT and it's a trike that has a very long and heavy pedal (since its steel and not aluminum like the dirtbike ones) and also the pedal pivots to the direction of gravity and not 90 degree like the front master lever which weighs like 50 grams?
    I wouldn't run the rear brake without the spring in any case. You also need that free play you get with the spring when riding...
    Στάλθηκε από το RMX2170 μου χρησιμοποιώντας Tapatalk
  4. #199
    Las Vegas, NV.
    2,540
    Quote Originally Posted by Antreas Sp View Post
    All valid points. Believe me, now that I’ve found a way to install the brake lever and spring, with the engine already in place, I will be running the spring, as it was designed to be.
  5. #200
    Buffalo, NY
    1,996
    That's a gorgeous frame color, it's going to look incredible when it finished
  6. #201
    Las Vegas, NV.
    2,540
    A lot more progress here lately. We had a parts cleaning party at my place last night, and got a lot of stuff cleaned up. It was mostly stuff that I thought had been cleaned up a long time ago, when this project first began. Luckily, I think all of the dirty work is behind us now.
    New front/rear sprockets, a longer DID X-ring chain, sexy, billet counter-shaft sprocket guard, and BVC rear sprocket guard have all been installed. The rear end is pretty much all assembled now, with the exception of the brake line. Now that the rear caliper & master cylinder are mounted, we can get it measured for the new brake line. The new CRF450R front brake caliper should arrive next week, and once it is mounted, we can measure for the new front brake line, and then order them both at the same time.
    The ignition/stator & flywheel have all been installed, and torqued to spec. A nice, billet kickstart lever was recently acquired and installed as well. The carburetor/airbox have been cleaned & re-installed. What a pain it's going to be to tune this carburetor, as you can't easily get to it with the airbox mounted. Any tips from you Tecate guys in this area?
    Mr. Tecate has been ordering a lot of new, or lightly used, and/or upgraded parts lately, as we are finally starting to see the finish line.
    Attached Thumbnails Attached Thumbnails Rear End.jpg   Engine4.jpg   Engine5.jpg
  7. #202
    Jan 2018
    California
    111
    Yes it is a pita, but I have found that some ultra high performance racing vehicles like, The TECATE...The Most Powerful 3 Wheeler In The Universe!, can be difficult to work on.
    You can remove the pipe and oil fill cap and take it out the right side or remove the airbox, then remove the carb.
    If you are running a straight thru, non spark arrestor silencer, and are at 2000 feet or less, and running pump gas, I would guess that starting with a main jet 2 sizes bigger than stock and the needle clip 1 position lower than stock should be a reasonable starting point.
  8. #203
    Jan 2018
    California
    111
    PS - Don't forget to tighten ALL your nuts and bolts...and rad shroud screws, after every ride.
    ...or try this, you might get lucky.
  9. #204
    Las Vegas, NV.
    2,540
    Quote Originally Posted by rpeters View Post
    Oh ok, that should be a breeze then.
    Thanks for the tip Barns. It looks like we’ll be swapping out for a new carburetor anyway, as this one has too many issues.
  10. #205
    Jan 2018
    California
    111
    LOL, well I didnt say it would be easy. It is unpleasant, but it is only around a 2 beer project.
    If I remember correctly a Mikumi VM series carb will fit. None of the pricey fancy azz carbs will be any better.
  11. #206
    Las Vegas, NV.
    2,540
    Oh yeah! This isn't my friend's first Tecate. Everything has been assembled with blue Loctite so far. As a matter of fact, I just asked him to pick up some more, as we are running low on the first bottle. When I installed the carb the first time, the tank and pipe were off, and I attached the carb to the airbox, and then slid the airbox 90% into place. Then I installed the slide into the carb, and slid the airbox completely into place, while guiding the carb into the reed valve boot. This was fairly easy, and we will probably follow the same recipe during the jetting process. Hopefully, with the pipe in place, it won't be much more difficult. We are probably going to go with a Keihin PWK carburetor.
    On my high-performance 250R, If I need to access the pilot jet, I remove the tank, pull the slide out of the carb, and loosen both carburetor boots. Then I simply rotate the carb, so I can remove the float bowl, which allows me to access the pilot jet. To make any main jet changes, nothing needs to be removed, except for the float bowl drain plug. I'm hoping the main jet will be just as easy on the Tecate, but we shall see.
  12. #207
    Jan 2018
    California
    111
    Yeah that is probably the hardest carb to remove on any old dirt bike or 3 wheeler I have ever worked on, and the snorkel obviously makes it harder. If they made an aftermarket air box for those, I would buy one then cut the snorkel off if it had one.
    As you know, if the cylinder has been ported as well, you would get more power with a 1 or 2 mm bigger carb as you know, but that is going to make removing and installing it that much more fun, plus the throttle cable may be an issue, but I would hate to leave some hp on the table if the cylinder has already been modified.
    Also, in case you didn't know, if you don't have a source where you can easily get original jets, Sudco in Long Beach still has them and will typically ship them the same day. I have bought over 100 jets an carb bowl gaskets from them in he last 2 years. 310-637-8330.
  13. #208
    Jan 2018
    California
    111
    You must have modified the engine quite a bit then.
    I have posted before that I like the 250r, and that friggen engine is as smooth as butter. Our target market was just different than Hondas because we didn't want to build a trike that was geared towards the same people that the Honda was because we knew that our trikes would have just been collecting dust on the Showroom floor if we did that, so we intentionally made one that was a bit more "high performance" than the Honda in box stock form. Honda easily could have done the same thing but their goal was different, and in this particular case, they had a much larger target market,
  14. #209
    Las Vegas, NV.
    2,540
    That was a Kawasaki trick done to Jimmy White's Tecate. It made carb removal possible without having to remove the tank. I will post the article for others to read.
    Yes, it currently has a Mikuni TM38 on it, but it has seen better days. Luckily the boots have been pre-stretched by this carb.
    Yep, I've used them before.
  15. #210
    Las Vegas, NV.
    2,540
    Just some minor modifications to bolt on a CR 250R cylinder, and it's still as smooth as butta!
    I totally understand, and mission accomplished!
