Page 18 of 20 FirstFirst ... 8 16 17 18 19 20 LastLast
Results 256 to 270 of 287
Thread: Time to see what all the Tecate hype is about?
  1. #256
    Buffalo, NY
    1,994
    It's been a long time since I've seen such a thorough build thread. Thanks for keeping us updated, great work
  2. #257
    Mexico
    9,020
    What you said.
    It sucks to get old
  3. #258
    Las Vegas, NV.
    2,527
    What you said.
    Thanks guys! I hate it when I’m reading through an old build thread, and when you get to the last post, there is no conclusion. Either, they ran out of money, lost interest, or something else. In any case you’re left hanging, wondering what ever became of it. So I strive not to do that.
  4. #259
    Dec 2006
    Las Vegas, NV
    423
    Looks absolutely sick!
    Nice work!
    85 350X, 85 250R, 99 TRX 90, 05 Predator 90, 05 TRX 400ex, 2019 RZR4 XP100
    FEEDBACK for Vegas250rr
  5. #260
    Las Vegas, NV.
    2,527
    Quote Originally Posted by vegas250rr View Post
    Nice work!
    Thanks vegas! It's good to see you on here again.
  6. #261
    Las Vegas, NV.
    2,527
    I got together with mr tecate last night for dinner, and to watch a Lakers game, followed by a Clippers game. I brought him some of his parts, off of his Tecate, that he wants to get polished (footpeg wideners, rear grab bar, airbox vent, & gas cap). In exchange, he had some freshly powder-coated parts for me, for his Tecate, as well as some 3/16" rivets to put the silencer back together. All of his Tecate parts were powder-coated years ago, when this adventure first began, so this small batch was for things that had changed or were modified during the build. The main item, which was the headlight mounting bracket, needed to be re-powder-coated, because it was modified (welded on) to work with the BVC, inverted fork kit. Then it was modified yet again (welded on) to add a bracket to it for a key switch. Also in the parts lot were, the footpegs, BVC front fender, adapter bracket, and an aftermarket KX250 shift lever, which was lengthened to work on the Tecate.
  7. #262
    Las Vegas, NV.
    2,527
    A little more progress as of late, as well as a slight setback. All of the powder-coated parts (footpegs, modified shifter, headlight bracket, & front fender adapter) have been re-installed, and the silencer was riveted back together. The polisher swung by and dropped off all of the freshly polished parts (rear grab bar, footpeg wideners, airbox vent, counter-shaft sprocket guard, & billet gas cap) that he had for a few weeks, and then he left with the silencer, so it could be polished as well. The new airbox lid was cut, to accept the airbox vent, and the vent was riveted to the lid. A front brake line guide was added, and the front brake was bled. A Blue Line decal kit was purchased, and a few of the decals have been installed, as well as some decals for the front fork protectors. And with any luck, the new seat cover will be ready on Monday.
    And now for the setback. As I began adding anti-freeze to the radiators, I started to see some drips on the floor. At first it appeared to be coming from the front, cylinder head nut, but then (much to my relief) I noticed it dripping off of the radiator hose, going from the cylinder head, to the left radiator. The clamp is tight, so it must be a hole in the radiator hose. No biggie, just another expense.
    Attached Thumbnails Attached Thumbnails Airbox Lid2.jpg   Footpegs1.jpg   Fork Protectors3.jpg   Grabbar2.jpg
  8. #263
    Las Vegas, NV.
    2,527
    We got the new seat cover back from CEET Racing Products. We sent CEET, the original seat pan/foam, and had them install the new seat cover on it. The green portion of the seat is a typical vinyl, while the remaining black portion is "gripper" style vinyl. We are very pleased with the looks of the new seat cover, and have nothing but good things to say about CEET Racing Products work, craftsmanship, and attention to detail.
    Because the carburetor/airbox is such a pain to install even 1 time, we didn't want to take it on & off multiple times, while jetting the carburetor on this thing, so we decided to get a UNI clamp on air-filter for the jetting process. And hopefully (fingers crossed), the jetting specs will transfer over, and work nicely with the airbox setup. While we await the arrival of the new radiator hoses, hopefully I will be able to button up a few little details, such as the fuel line routing, inline fuel filter placement, & a few other odds & ends.
  9. #264
    Las Vegas, NV.
    2,527
    Mr Tecate stopped by tonight, and we got a some work done on his Tecate. To protect the new rear fender plastics, from the hot exhaust pipe, we added some reflective heat tape, to the underside of the fenders. After test fitting the rear fenders with the new seat cover installed, of course we had to take a few glamour shots. We also got the fuel line routing & fuel filter location figured out.
    Mostly though, we stood around, drank beer, and admired how she is turning out. Oooohhh she is gonna be sexy!
  10. #265
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    433
    Awesomeness!
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
  11. #266
    Las Vegas, NV.
    2,527
    We received the new, aftermarket, '85 KX250 radiator hoses a few days ago. Most of the hoses needed some trimming on 1, or both ends, to fit properly, as is usually the case with aftermarket, silicone hoses. The new hoses are installed, all of the clamps are tight, and the radiators have been topped off with coolant, and so far, there are no leaks. Mr Tecate also picked up a new silicone hose for the radiator-to-overflow tank line, as the original one was a bit short for how we wanted it routed.
  12. #267
    Las Vegas, NV.
    2,527
    We finally had our first start attempt last night. Needless to say, I've been worrying about all of the things, that could go wrong, after such an extensive rebuild, on an unfamiliar bike. I've never worried like this after rebuilding my 250R, but it has never been apart for as long as this Tecate has. After adding fuel to the new tank for the first time, there was a little seepage from the petcock-to-gasket-to-fuel tank, that was remedied by tightening the petcock bolts a bit. I'm worried about tightening them too much, and pulling the brass inserts out of the tank.
    After that hurdle, we turned on the gas, and had a little fuel leak from the fuel line-to-fuel filter joints. This fuel line fits the petcock, and carburetor inlet nicely, but is a tad loose on the inline fuel filter. That was easily remedied, by eliminating the inline fuel filter temporarily. We will most likely end up replacing the inline fuel filter with a different one.
    It took several kicks, but she finally fired up, and came to life! She ran for about 15 minutes total. So far there are no issues. All of the wiring is correct, with lights/kill switches functioning properly, and no coolant/oil leaks noted. The jetting (pilot) seems pretty close as well, but some fine tuning will still need to be done. So far though, she is idling nicely, and responds fairly crisply, when blipping the throttle.
  13. #268
    Las Vegas, NV.
    2,527
    Another video. She's alive!
  14. #269
    Buffalo, NY
    1,994
    That sounds awesome. Great job!
  15. #270
    Jan 2018
    California
    111
    Mr Tecate stopped by tonight... ...we stood around, drank beer, and admired how she is turning out. Oooohhh she is gonna be sexy!
    Did you forget it's not a Honda you are talking about?
