Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 1st Gen Tecate Fork Bushings
    Jan 2013
    minnesota
    5,911
    welcome back after your long hiatus.
    are you referring to the approximately 1 inch long bushings that are on the outside of the bottom of the inner fork tubes?
    99gsxr750 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Eastern Pa
    219
    I need those too. I've been trying to track down a set of 82-83 yz100 bushings without much success, but I'm referring to the little white seal on the fork cylinder. Can be seen here in this ebay auction.
    https://www.ebay.com/itm/KAWASAKI-NO...EAAOSwiMRbEbMN
    Sep 2005
    MICHIGAN
    2,027
    http://www.3wheelerworld.com/showthr...ngs#post810936
    post #83 from this thread
    1985 KXT FORK BUSHINGS:
    The oem fork bushings are discontinued through kawasaki. But... since these forks are nearly identical to the 1982-83 Yamaha yz 100, the bushings are exact replacements. Yz units are longer and have a bit more travel, but the components in leg are same. Even the oem yz fork seals and dust caps are better quality imo.......Kyb was the supplier for both machines, so this allows me to rebush all of my 85 kxt forks thanks to Yamaha still carrying replacement wear items.
    The thread may contain more useful info for you
    86 T3
    84 T3
    86 KX250
