Results 1 to 15 of 27
Thread: Electric motor help ...Is anyone here a master of Electronics?
    Nov 2013
    Oxford CT, New Haven County
    984
    Help me Ohm-y Watt! You're my only hope!
    lol,lol.. Ok Stupid Star wars Reference out of the way... Now down to seriousness!
    I have a DC motor, 110 Volt, I wanted to use it on a small lathe but I need it to be 110 Volt AC. Is there a cheap and easy way to do this?
    I have looked for converters on line but they are all either to convert 110 AC to 12 or 24 VDC or to do the opposite. The motor in question is supposedly off a Grizzly Mill / Drill machine
    but when i went to the site Grizzly says its a universal motor, It isn't.. its A DC motor. It looks exactly like the DC motor on my Harbor Freight 7x10 Mini lathe to be honest.
    So what is involved with converting AC to DC.. is it worth it or should I save this as a spare for the mini lathe and continue on searching for an AC motor?
    I was stuck on finding a 250 Watt, 110 or 120V ac motor for some reason... but there are a fer 115 watt AC sewing machine motors on Ebay that may seem to work. I want to replace a tired Unimat DB 90W lathe motor so I can actually work with it. And I'm building a sherline mill and I want to upgrade the tired motor on that also.
    Sep 2013
    Southern Wisconsin
    24
    Usually D.C. Motors are used because you can get variable speed out of them. They take a range of voltage to make different speeds. You best best is probably a power supply and maybe a dial to adjust speed much like a train set. Any pictures of the motor plate would help.
    84-200x
    83-200x
    84-200es
    84-200es
    82-250r
    84-70
    84-125m
    83-200e
    85-350X
    83-185
    19??-110-never really looked at the year
    That's not previously owned..I ride them all every couple of months!!
    15-20 other parts and pieces machines that keep mine all running for cheap!!
    TTown, Alabama, United States
    845
    I think the simplest, ok maybe not the simplest, but the cheapest way to do that would be to build a 4 diode bridge to create a rectifier, however i have no experience with 110v applications and i don't know how much voltage you would lose doing that, maybe someone else will chime in with the diode and cap specs you need for something like this, what you need will depend voltage ratings and the amperage draw of the motor.
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
    Scootertrash's Avatar
    In the sticks
    4,638
    I'm not sure how one can tell if an electric motor is "tired". They probably just need a cleaning and maybe some lube.
    I would take them apart, pull out the commutator shaft and clean the slots between the copper bars, scotch brite or fine sand paper to clean the copper bars clean everything up with an electrical cleaner, NOT BRAKE OR CARB CLEANER! Make sure any and all bearings and/or bushings don't have excessive wear and replace any that are worn, make sure the brushes aren't worn down to nothing (I typically just replace the brushes, they're cheap) then put them back together.
Name:	Armature and commutator.jpg
    Your commutator should be clean and shiny, not look like this:
Name:	dirty commutator.jpg
    You commutator bars should be nice, straight, and flat. Not grooved or dished.
    Post some pics of these motors
    Last edited by Scootertrash; 02-06-2017 at 11:31 PM. Reason: To add important info
    Aug 2015
    Idaho
    842
    Watts happening! Did you get it figured, yet? You would need a dc 'variable speed motor controller' for a dc motor. If you get the right one, it has everything in it. It has a dial, like stated above.
    Nov 2013
    984
    how does a DC motor work on AC? I mean, My lathe works fine, plug it in and it goes like hell! lol... thats got the same DC motor on it.
    Nov 2013
    984
    Quote Originally Posted by Jd110 View Post
    but is that all I'd need to make it run off AC house hold current? or do I need something to convert it to DC first? do you have any links to where I can find one of these?
    Thanks!
    Nov 2013
    984
    Yeah... By tired i mean they seem to be running slower than they should. I can try and clean em up some and see... but I believe the sherline motor is a DC also ... the unimat motor may be AC i will have to pull them both apart to check.
    Aug 2015
    Idaho
    842
    Sure, here it is:
    http://vi.raptor.ebaydesc.com/ws/eBa...=1486391838779
    Aug 2015
    Idaho
    842
    Quote Originally Posted by czac View Post
    X2 on checking your brushes and cleaning the commutator. That's where you check the resistance on the windings (between the bars on the commutator). I'll try to help you as much as I can but you will want to do some research. It is electrifying, as you know, so be real careful. Sounds like a fun project.
    Mar 2009
    new england
    1,391
    I will try and grab you a pic of what I did. took the AC and bridge rectified it, added a capacitor. I used an AC rheostat prior to the rectifier to control speed. (I did this as speed control died on the dc motor) Now I gotta sell that small cnc lathe and mill-gone bigger
    Nov 2013
    984
    Sure, here it is:
    So with this not not only controls the motors speed but it converts ac to dc? Cool!
    Nov 2013
    984
    Cool thanks!
    Nov 2013
    984
    Cool... so you basically did the same thing i am trying to do? How did the motor work with this set up? Did it lose amy power?
    Aug 2015
    Idaho
    842
    That's right. Similar to what a VFD will do for your AC motor. There's a bit to know here. Sounds like plastik has tricks up his sleeve converting his AC back to DC.
