Results 1 to 15 of 23
Thread: 200x 350x speedometer Drive gear
    andnuaa's Avatar
    andnuaa is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2007
    Miami,FL
    217
    Quick question I have two speedometer Drive gears one I believe is for a 83-85 200x and the other one I believe is a 350x so my question is how can you tell them apart ? also the worm gear on One turns counter-clockwise and the other one turns clockwise. Will upload pictures as soon as I get to the shop
    Thanks for the help in advance
    andnuaa's Avatar
    Sep 2007
    Miami,FL
    217
    Speedometer
    Pictures of the gears
    Attached Thumbnails Attached Thumbnails 20170216_081414.jpg   20170216_081442.jpg   20170216_081457.jpg   20170216_081511.jpg
    Mar 2003
    Australia
    1,919
    Nothing stamped on them, 350x should be HA5.
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    No, they are not always stamped because I have a few of these. (I lost your phone # BTW).....
    If you stare down into it and stand in front of the trike, your looking at a right hand drive and if your rolling the tire forwards the cable drive in that drive box will rotate clockwise to be correct.
    Remember, your in front of it and the 200X drive will be on your right, but sitting on the trike it is actually a left hand drive.
    With a 250R and a 350X, the caliper is on the left so the drive is on the right. Those are typically much harder to find/buy etc etc and there are no other options with street bikes and gears etc because you can't seal them correctly and/or buy the gears inside to run a 23.5" tire.
    The left hand drive sitting on the trike is for a 200X because a 200X has a caliper on the right hand side. Be careful though as the LH drives include big Reds etc etc and are for a 25" front tire, not a 23.5".....
    They (200X, big reds etc) will be located on the left and rotate CW if you are STANDING IN FRONT OF IT LOOKING DOWN.... The ones that look like a "b" are left hand drives. A "d" is the 250R/350X or a right hand drive.
    Sorry if this is a bit confusing, I need to figure out how to post pics with talp-a-talk so it's understood better.
    I have 250R/350X big red, 200E, 200S drives but listing them here doesn't work pricewise, I just use EBAY....
    110 atc's Avatar
    110 atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    green bay
    238
    Can the gear drives be rebuilt and resealed in any way? I have a 185/200s and a 200x gear drive that have come apart in two pieces.
    1982 110, 1982 Big Red, 1983 70 Christmas Special X2, 1983 185s, 1984 200s, 1984 200m, 1986 250r, 1987 125m, 1987 lt500r x2, 2003 Rincon, 2008 700xx, 2016 pioneer 1000-5
    Apr 2002
    s.w. michigan
    6,498
    Quote Originally Posted by 110 atc View Post
    Yes, they are very serviceable (and thee most neglected part by far).
    Most likely the large internal snap ring (circlip) came out (difficult to remove by hand so NO idea how it would have come out in the first place)
    andnuaa's Avatar
    Sep 2007
    Miami,FL
    217
    Is there any other bike that more common that has a drive gear that will work for the 200x ? Because as you can see in the picture it's been snapped off
    Mar 2003
    Australia
    1,919
    You can likely change out the worm gear. You would just have to find one from a bike that will work, that could be expensive. If you want to sell the 350x one PM me. Thanks.
    110 atc's Avatar
    Nov 2007
    green bay
    238
    That's cool. Where can these components purchased? I am not in a hurry as these are just extras.
    Good luck, I have found nothing that fits, nothing. I can spot the right worm gear a mile away and all the street bike worms angle is cut opposite and less teeth than required.
    I simply got lucky to purchase many drives at decent prices.....
    Mar 2003
    Australia
    1,919
    That's a shame, I know a cb350 worm gear will work in a 250es. I had to do that to mine as a moron (Louis Rego) on eBay sold me a 200es one goodluck with it mate anyway and let me know if you want to part with the 350x one.
    Matt
    andnuaa's Avatar
    Sep 2007
    Miami,FL
    217
    Quote Originally Posted by atcmatt View Post
    Matt
    I figured it would be a mission to find the right driving gear for it.
    Anyway Matt I'm actually going to keep the 350X gear for my project that I am currently Gathering parts for
    Mar 2003
    Australia
    1,919
    Too easy mate, I have a 250sx one on my 350x and it works fine though it would be nice to have the right one for it. I'm pretty sure all the internals are the same on these gearboxes. The only difference being the left and right hand worm gear and pinion gear.
    I have the new seals in stock.....
    I will say this, the 200E, 200, 200S are exactly the same and for a 25" tire, I have 4 of them.
    I have 5 or so 350X or 250R drives (ONLY 4 SALE ON EBAY).
    The 200X SHOULD be different. I just won a whole 200X kit in the Hondaline box from DONZI on EBAY yesterday.
    Next week I will know every housing, every gear and every application!!
