Results 1 to 3 of 3
Thread: Idling way to high
    Feb 2017
    Paragould
    63
    Idling way to high
    I ordered a new carb and throttle. Do you guys think that would fix the problem? It's a 200s
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    Have you adjusted our idle mixture?
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Apr 2014
    Edmond, KS
    2,591
    If you cleaned your carb, make sure you put the slide back the right way. You can install it 180 degrees off and it will idle extremely high. I've done this a few times.
