Results 1 to 1 of 1
Thread: YZ250 sprocket collar 90387-25663-00 in a TRI Z.
    Dec 2016
    NC
    42
    Can anyone tell me if a sprocket collar PN 90387-25663-00 will fit on a TRI Z. Thanks. The outer diameter has to be the same because the tri z shares the same oil seal PN 93102-32M07-00. But the transmission shaft is a different part number, maybe that's the difference. Being the inner diameter of the collar. I was wanting to change the collar since it had pitting and rust, it also looked like it had been leaking. I'm replacing the seals and didn't want to tare a new seal up.
