Results 1 to 8 of 8
Thread: US90 Running issues.
    Feb 2017
    Minnesota
    4
    Thumbs down US90 Running issues.
    Hi guys. I have a US90 I picked up a few months ago and it has had issues running since then. It will idle forever but whenever a load is put on it or the throttle is floored, it bogs down and dies. It has a brand new 16mm Keihin carburetor on it that I purchased to replace the old identical carb it had on it because some parts were bad inside. There are zero exhaust leaks and all of the intake gaskets are intact. It doesn't foul spark plugs. The needle in the throttle is set for the highest gas ratio (I've tried it at all levels and the most gas worked the best). Would timing be an issue with this? Please help!
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Have you adjusted the points?
    Feb 2017
    Minnesota
    4
    Sorry I took forever to reply. I have no idea what the points are, is that on the stator?
    Feb 2017
    Minnesota
    4
    I lied. I know what the points are, just how should i adjust them for a lean or rich ratio? I can get pictures for reference if needed.
    Cold Lake, Alberta, Canada
    3,019
    I agree with gimme, clean and adjust your points and go from there. Do you have a manual?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Apr 2016
    CA
    10
    Indeed, points.
    Feb 2017
    Minnesota
    4
    I do have the manual. I'll have to go get it from my friends shop today, will it have the diagrams I need to adjust it properly? Thank you
    3,019
    Yes, it should be fairly straightforward.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
