Results 16 to 30 of 52
Thread: DG RCM1 exhaust mod for 350X
    The Open Road
    4,736
    Nice mods. I hate those DGs. I don't even know why they put a screen in them like that will slow down soundwaves thru a 2 inch hole straight through it. It's a resonator.
    Thanks for the disassembly tip too. Clever hide behind the tag.
    Mar 2017
    lafayette, louisiana
    thanks for the info.
    I just copied this and ordered the quiet core for the HMF and ordered the packing for the FMF. Hope it's as easy as you guys say.
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by lafayette350x View Post
    I'm gonna do a tear down with pics hopefully Sunday. While your waiting go buy a stainless steel sink screen from Home Depot. Like 5$. We'll build you a spark arresstor.
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    Let us know how it goes. I want to try this.
    Sep 2014
    Oregon
    591
    Any updates on this. A build thread would be awesome.
    Trikes owned:
    83 Honda 200x "Liquid X"
    81 DG 250r : Sold
    Sep 2016
    Phoenix, AZ
    307
    Last time I was checked, they wanted to see the usfs approved spark arrestor stamp which my supertrapp has.
    That said, I still want to do this mod once the other x is running for noise reduction.
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by x-rider View Post
    I'll do a quick tear down with pics maybe this week. Been busy with riding and work. Also 3 kids.
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by Ranvier View Post
    I just went to a park run by rangers who check. He looked did the stick test and said "nice three wheeler. HAvent seen one that clean in a while. Have fun"
    Sep 2016
    Phoenix, AZ
    307
    Quote Originally Posted by Shawn Powell View Post
    How many decibels?
    Feb 2017
    Corona CA
    858
    How many decibels?
    95 db
    Feb 2017
    Corona CA
    858
    So this is a long over due. I tore this down to replace my spark arrestor ( had a ranger question placement apparently it needs to be after the packing. Mine was In front. He still let me pass through and ride. Just asked me to fix it before I came back) so here we go with pics
    Drill these rivets out there 1/4"
    Remove plate
    Remove set screw
    There's a c clip buried in there holding muffler body in. I use a small flat screwdriver to pop it out and grab it with pliers
    Pull body out. You can see where I put my old spark arrestor. That's a 5$ sink strainer from Home Depot molded to fit. Worked fine but I guess it's supposed to be AFTER the packing. I never knew. Had a lot of ranger look at my bike and never question it. No big deal. Move it to the other end. I owe 3ww a build thread anyways.
    You can see how I back bolted the turn down through the body. The quite core is sandwiched in between the body and the turn down
    Here's the quiet core. I had to cut it down to about 3" It was longer than the muffler body when I got it. HMF said it should be about 40% of the muffler body length. 3" seems fine.
    Here's my new HMF legal spark arrestor quiet core fits under that. All gets wedged under the turn down. This is all bought from HMF off amazon ,quiet core turn down and spark arrestor ,for about 50$
    Reverse process. Ride and enjoy your now forest legal DG exhaust. On heavy modded machines I wouldn't run the core. Always spark arrestor and turn Down. It reduces the flow from 1 5/8" to 1 1/4". That's a lot! It did put a damper on my top end but gave me bottom end grunt.
    Next year I'm going to do a 400ex header and a FMF q4 muffler. This is temporary but works well and sounds good.
    Feb 2017
    Corona CA
    858
    Also this has nothing to do with this mod but does concern this exhaust. I have been getting a leak at the header to muffler connection. With DG there is no gasket there and with the aluminum system there is no clamp. Friction fit. Well after 1500 miles(that's verified via gps) and 2 years it's a bit loose. I tried bronze silicone burn right up. So I made two 3/4" long slits with my dremel and bought a Hose clamp to crush it down. Also used black silicone this time. (700 degree) we will see how time takes it. But hisnis how my 400ex connection is and doesn't leak after 15 years. Enjoy.
    Apr 2014
    Edmond, KS
    2,591
    Thanks, Shawn. Very informative.
    Sep 2016
    Phoenix, AZ
    307
    Thanks for the pics and info. Will try it.
  15. #30
    Sep 2014
    Oregon
    591
    Sweet tip. I may try this mod. Thanks for sharing.
    Trikes owned:
    81 DG 250r : Sold
