Results 1 to 14 of 14
Thread: Sickle bar mower
    Connecticut
    1,605
    Sickle bar mower
    I am in need of replacement parts for a JARI monarch mower. Not interested in spending $340 on a set of tire/rims. Does anyone know of other equipment that used a 16x2 solid rubber tire?Click image for larger version.
ID:	240375Click image for larger version.
    Could probably continue to run these tires if I used an adhesive to fill the dry rot cracks but finding a source for new ones would be awesome. Thanks in advance for any info on places that offer these style tires and rims.
    Cold Lake, Alberta, Canada
    3,019
    Here's a long shot. Would putting a cut to length, cogged serpentine belt upside down riveted to the rim work? Reaching here.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Jul 2003
    indiana
    892
    Hard to find. I see some at tractor and engine shows I go to but don't have a source for new ones. Pic of the whole machine? I think I know exactly what one you have.
    Connecticut
    1,605
    These mowers are pretty bulletproof
    3,019
    Cool machine, restoring it or just using it as is? I was thinking if you wanted to protect the current rubber, stretch a kids bike tire over it and it can take the beating.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    6bt's Avatar
    6bt is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2017
    near Syracuse NY
    318
    Or even a couple old snowmobile belts, cut, flipped over and bolted/riveted on.
    Sent from my XT1254 using Tapatalk
    Mar 2012
    Glen Rock, PA
    551
    I gave a trashed and flat set of dry rotted woolyboogers to my friend; who cut the tread off and epoxied them to his son's bald Power Wheels plastic wheels. Actually worked really well, but I presume you want to keep the original look?
    Ragin' full on...
    Aug 2016
    East of Worcester ma
    1,372
    Interesting how the top spindles drive the wheels like a gear. Maybe try these with some time w/a tire groover. Probably would have to rework center spindle/bearing though, and im sure the metal isn't as beefy.Click image for larger version.
ID:	240476 Click image for larger version.
    Shep
    Ive got an attachment for an old gravely you may be interested in i'll post a pic shortly, just not sure if your machine has connection point for it. Here it is Click image for larger version.
    Jul 2011
    Cato, NY
    33
    I have one of these exact same machines. It has no engine. I put one on it shortly after I got it and it worked fine. The engine has since been removed for other projects as I have a better rough cut mower. The cogs on the wheels are somewhat worn. The small drive spindles seem to show more wear than the tires. Last I looked, there were no cracks or splits in the hard rubber. I see your in Conn. Not to terribly far from NY. I'd sell it for what I paid. $25. Been thinking of selling my trikes too. Two 110's, one runs, rough, the other is a parts machine. Also a 125M that runs well but sometimes jumps out of second gear. Let me know if your interested and I'll go out and have a closer look at it. It has been stored, covered, outside for awhile.
    It was actually a smooth running machine but I would joke with friends about the name, Jari. It will Jari you all over the place when you run it.
    Mar 2009
    new england
    1,391
    Forget the rust pile , I want to see the turning center or the red car (944?)u are hiding!
    Connecticut
    1,605
    Our company would be happy to sell you a German built Swiss lathe. We currently have a trade in 2012 36mm machine and a brand new 20mm Swiss.......For $160,000 someone can buy our 20mm lathe with a barfeeder, 4 port oil pump and a mist collector.
    The 944 is an 86 non turbo that the boss man picked up to use when he visits from Germany
    Connecticut
    1,605
    Quote Originally Posted by wheelsforheels View Post
    Thanks for that generous offer! I am certainly interested and do travel to NY on occasion
    Mar 2009
    new england
    1,391
    Darn, thought they were your toys. I wish I had a job shop that needed such a lathe. What I do does not require cnc though I did just add a cnc mill to my shop
    Jul 2011
    Cato, NY
    33
    Quote Originally Posted by sledcrazyinCT View Post
    I'm generally around here at home. Just don't visit this site often. I don't like putting my phone # on the internet though. We would both have to be online at the same time. I'll post my #, then delete it 5 minutes later.
    I love to see old things like this come back to life. I originally bought mine for mowing copious amounts of goldenrod on a steep hillside. Very stable machine for off camber applications. Just don't cut all that fast.
