Results 1 to 14 of 14
Thread: Help! Brakes...Caliper bad or?????
    nitekrawler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    430
    All the stuff came in for the rear master cylinder (Banjo bolt) So, I installed it, bleed the brakes, fluid came out :-D Though, great! Son will be suprised when he comes home from school today. WRONG! Caliper doesn't close :? Now what :?: :?: Can you rebuld these? OR?
    1982 Honda Atc 250r - Daughter's
    1982 Honda Atc 250r - Son's
    http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
    Jul 2003
    430
    Update: Took rear caliper off (pain) and piston was frozen, got it to move freely, BUT! Now it leaks fluid from behind the pad Did I break it? The pistion has this black crud on it, we removed it, but I am wondering if it was a seal of some sort. I am at a loss. Help :?:
    Apr 2002
    s.w. michigan
    6,498
    brakes
    i think you might need a couple of new seals in your caliper nitekrawler.
    at least the big one that fits inside where the piston is. there is another one thats alot smaller the the piston rod goes thru and is very hard to see. it normally leaks thru from the back side so your might be okay but i would replace them both.
    to remove the piston from the caliper your use air pressure. take the bleeder thing out and put a air nozzle up against it. it will pop the piston out.
    john
    Jul 2003
    430
    Question :-D When I look at the piston, there is a hole :shock: I see some parts. I'll try to post a pic in a sec. Tell me if its normal?
    Ron
    Jul 2003
    430
    Had my son hold it while I took some pics. The hole is small, and you can see like the rod mabe and a "c" clamp? Not really sure what I see
    Jul 2003
    430
    Is the top of the piston supposed to have a hole where I can see inside it?
    Apr 2002
    s.w. michigan
    6,498
    brakes
    nope ,,, no holes in the piston nitekrawler. that's where the fluid is getting pushed thru i bet.
    i haven't ever heard of those pistons rotting away but suppose they could. amazing as to what a fella comes across in these 20 year old trikes.
    john
    Jul 2003
    430
    How easy or whats the trick to getting it back in :?:
    Apr 2002
    s.w. michigan
    6,498
    brakes
    not to bad to re-install. you just want to make sure every thing is clean and you kinda lube up all the parts with brake fluid. it takes a fair amount of presure with the thumbs to press back in.
    john
    Jul 2003
    430
    Took it apart, and o-rings are shoot too :?
    Nov 2002
    1,189
    I bet a rock or something was between your pad and caliper, and when it was pushed, the rock pushed through.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Jul 2003
    430
    Quote Originally Posted by plkmonster2
    Bummer :? Poor son has been waiting to ride this...Argg.
    Jan 2004
    74
    I don;t see why he can't ride it I have no back brakes on my 250r I just know I have to watch out caz I can't stop as fast
    83/84 honda act 250r
    parts needed new exaust head pipe, shift shaft the list is forever growing
    87 yamaha warrior trying to get fixed up for a dd
    parts needed upper left ball joint, front shocks, front tires, read break system
    Jul 2003
    430
    Quote Originally Posted by ste-pel
    I did :-D Tapped up the brake lines 8) so no dirt gets in
