Thread: VTX 1800 triples and forks
    Dec 2016
    NC
    42
    Does anyone know what forks Kasey was using on those VTX triples? they don't look like CR forks. I got KYB when I asked.
    Dec 2016
    NC
    42
    Quote Originally Posted by pervO View Post
    ok so they are aprilia wont be using those. anyone know anything that fits these triples without making bushings 56mm top and bottom.
    Dec 2016
    NC
    42
    Here is what I got so far. 1989 CR250 forks.... I know they aren't the best and they need a rebuild but they were cheap and hopefully they will be better than the small forks that came on my 85 tri z. (that were also bent and blown out) I might give racetech another call after I get this all mocked up and see how much they would charge to change the spring and such. The bottom clamp slid on beautifully the top... not so much. They are a little to big, maybe the VTX1300 top clamp will be smaller? I've emailed a few sellers on eBay to see if they could take some measurements. (I know I'm that guy). They also have an axle that threads into one side, even though its not the same threads as the tri z maybe I can get an axle made somewhere. Here is something people don't do around here.. the measurements are 55mm on the upper 57mm on the lower with a length of 36 3/8 from axle to top.
ID:	240598   Click image for larger version.
    Freedom Township, MI
    642
    Very nice and thanks for the measurements
    Sent from my SM-G930V using Tapatalk
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    Dec 2016
    NC
    42
    Running into problems, mainly with just the width of the vtx triples they are only 10 1/4 center to center. The Honda hub that Kasey has on my first post is real tight, you will have to take the studs off the hub and make an adaptor for the bigger dirt bike rotor. (I was thinking of cutting down a stock Honda ATC rotor to use as the adaptor since it had the correct bolt pattern to fit the hub, or maybe just using it as a template to transfer over to aluminum). More to come when I can buy my own Honda hub (currently borrowing from a buddy for measurements). If anyone has one for cheap let me know.
    Aug 2020
    Titusville, pa 16354
    What did you end up finding out? I know it’s been a good time since this was made but can’t find the answers I’m looking for.
