Results 1 to 15 of 15
Thread: FST Dual oil coolers for 350x help
    Feb 2017
    Corona CA
    827
    Does anyone have a picture of these? I'm contemplating it due to living in Southern California. Would like to see what it looks like and how it's mounted and ties in? I don't have a home based PC so I can't access FST website. Thanks in advance
    Hyndman PA
    1,905
    The pics and mounting info comes with the cooler kit, there are no pics on my site.
    Feb 2017
    Corona CA
    827
    Quote Originally Posted by Mickey Dunlap View Post
    Ok thanks. I wasn't going to bother you with my silly questions after I saw your FB post seems like your a busy man. One last question regarding mounting, do I have to weld anything? Thanks a lot.
    Freedom Township, MI
    642
    Hey if you get this installed on your x can you please share some pictures with us? I've also been wondering how this is setup.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    Shawn I have been looking at a xr400 cooler.
    Feb 2017
    Corona CA
    827
    Quote Originally Posted by Ranvier View Post
    To mount where, on the front tube? And to replace or as an extra? How do you tie the two in? FST kits don't cost that much I was just wanting to see what it actually looks like. I was even contemplating dual 400ex coolers. But we'll see. Not gonna be till my summer tear down either way. Was just gonna start stock piling parts
    Sep 2016
    Phoenix, AZ
    307
    Quote Originally Posted by Shawn Powell View Post
    Was going to see what capacity was. Ideally just run one and if it fits on the stem would be clean but a kit would be simpler. My big bore motor was in a quad frame and had a big single oil cooler.
    Feb 2017
    Corona CA
    827
    Yeah my motor is super mild. .050 over wiseco stock cam 400ex carb and full exhaust. Stock air box with k and n with lid even. (Lots of muddy trails) and some super mild porting. Just got rid of the casting flaws basically. Runs fine and I switch to 20 50 in summer. But I'd still like the duals especially when I take it to the sand (if I ever make it out there.)
    Jan 2013
    minnesota
    5,911
    What oil are you using?
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    devore,ca
    1,017
    Shawn,
    although I like the idea of more oil cooling-the more the better- I wouldn't be to concerned about it getting too hot. I ride the piss out of all my 350x's here in the Cali desert and I have a friend that races 100 mile desert races on a 350x in the Arizona desert and they seem to do just fine.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Feb 2017
    Corona CA
    827
    I use the basic Honda gn4. Change it often and use Honda OEM filters. That's in all my bikes. 10 40 winter and 20 50 summer.
    Jan 2013
    minnesota
    5,911
    That's decent oil but nothing special and it shears to a lower viscosity . You might consider a shear free Group IV synthetic oil like Mobil 1 20w-50 V Twin oil . Auto parts stores and motorcycle shops and walmart sells it.
    Feb 2017
    Corona CA
    827
    Is that rated for a wet clutch? I've never cared for synthetics in older style motors. Haven't had any problems but do plan on hot summer rides.
    Jan 2013
    minnesota
    5,911
    Yes.
    Why?
    Group IV and V oils are virtually shear free which means that their viscosity will remain consistent and never shear to a lower viscosity . The also have a higher flash/burn point than lower rated oils which means they will not as easily get cooked off the surfaces from high heat.
    Feb 2017
    Corona CA
    827
    Yes.
    Why?
    Every time I've ever put full synthetics in my older style motors I've gotten more engine noise. From my bikes to my older ford engines.
