I'm gonna dress up my trike a bit. First off is the exhaust. i'm gonna paint it black, heat safe, of course. But, is there any heat safe clear coat? Will just plain paint hold up if i sand the pipe and clean it up first? Thanks.
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
I used bbq paint on mine
83/84 honda act 250r![]()
parts needed new exaust head pipe, shift shaft the list is forever growing
87 yamaha warrior trying to get fixed up for a dd
parts needed upper left ball joint, front shocks, front tires, read break system
I used high temp engine/manifold paint. Seems to hold up well. I don't think there are any clearcoats available. I would just do a couple coats. Really makes your rusted exhaust pipe look a lot better!
-86 Polaris Scrambler 250r/es - sold
-84 200es Big Red
-92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
-87 Jeep XJ 5" lift/many other mods-sold
-89 F-150 4" Lift/33s
-90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
Ask me about custom cut decals!
Put that stuff on my old truck exhaust back in the 90's and burnt off :?Originally Posted by ste-pel
1982 Honda Atc 250r - Daughter's
1982 Honda Atc 250r - Son's
http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
Now Dupli-color makes a super high heat paint, it goes up to 1200 degrees availible in black for sure, and they also make a 500 degree clear coat. Both are under 5 bucks a can. Hope this helps. Kaysen
1985 Honda atc 250R- All stock with DG pipe & UNI air filter. Many Mods to come
1983 HONDA 185s- Custom Cobra pipe- 102 main jet- UNI filter- Turf Tamers
1970 Oldsmobile Cutlass Rallye 350 all original
i put some bbq paint on my stock exhaust for my 200x and i fired it up and it burnt right off it said hight temp up to 1300
1985 atc 70 (sold)
1985 200x dg pipe and k&N filter
need rear brake caliper for 200x
Well, i got some rust-oleum high heat paint. good up to 1200 degrees. i'm doing 3 coats or more. I got the silencer cleaned up real nice. Took a good srubbing with a wire brush. the stock color is a dark gray, I think, but I'm going black. It's a good brand, so I don't think it should burn right off. Works on our 2000 degree stove, so.... Hmm, I'll do a heat test tmrw, I'll take an acetylene welding tip and see how much heat it can take... I'll reply tmrw!
My Rides
Yamaha 200E
Sorry for the bad post. Blame me, blame me, lol, I'm really tired.
My Rides
Yamaha 200E
Another question, about painting. How do paint the cylinder and head? Right now, I'm Just thinking of stripping off all the chipping factory paint on there now. This trike was run at the beach, so it has that salt problem :? Not a bad trike for what I paid for it, but now, I want it to be a bit better. :-D I'm going to touch up on the side cases, cause i still want them black. Makes the engine look awesome. :shock:
My Rides
Yamaha 200E
hey whiteboarder,
i bought some high heat paint, and if you notice the "up to 1300 degrees" it probably says intermitant. a car or truck usually gets hot and cold and doesn't stay constant. a bike's heat is constant. i paid like ten bucks for a can that burnt off after about a half hour,
yet a 4$ can has lasted quite a while.
I've got the silencer and header almost done. They are looking really good. The black is a matte color, so it looks almost stock, but is a bit darker.
My Rides
Yamaha 200E
Huh?? When does your automobile cool down during a 2 hour drive???Originally Posted by leprogle
I've used the Rustoleum on both 4 stroke and 2 stroke exhausts with fantastic results.
I do prep by sandblasting and wipe it with lacquer before spraying. I also place the can in super hot water prior to spraying to warm up the paint - works for me!
