16” Hammer, jay
I have the table saw/shaper from them and have loved using it over the years
All this talk about CDIs and stuff motivated me to try to figure out the "no spark" issue with my DR.
Looks like the coil checks out fine......that leaves the $350 cdi a suspect. Stator and pickup were all new so they checked out fine. I'm going to dip the tips of the connectors in some acid and wash away some varnish and check again but according to the manual some things don't resistance/ohm out correctly.
knappyfeet, I'm gonna make a friendly suggestion. Buy yourself a Fluke meter or something higher end. I've had a cheaper meter give me some off the wall readings before that led me down the wrong path while troubleshooting electrical issues.
Fluke is always a good choice! I have a Fluke meter at work and I use a Field Piece here at my home shop. My Field Piece meter is an HVAC tech meter but it works great for mechanical applications too! Comes with an Amp Clamp and a temp probe too. A more expensive digital meter is worth every penny
I'll get a Fluke.
It's funny.......the manual calls for a specific Suzuki Pocket tester that's an old swing meter. Apparently any other meter will give false readings for the CDI....go figure. It was told to me the amount of current is what is important on the CDI test. And an old one on ebay is as much as a Fluke.
You guys know your Fluken stuff.
Ohm glad you didn't find my comment re-volting.
Lmfao I can't keep up with you guys. I think of things but usually once I start weighing out the positives and negatives I get overwhelmed and pop a fuse.
Watt chew talkin' bout, Willis?
I'm out of puns, looks like a draw.
