Page 22 of 312 FirstFirst ... 12 20 21 22 23 24 32 72 122 ... LastLast
Results 316 to 330 of 4679
  1. #316
    NEPA
    7,051
    Quote Originally Posted by 6bt View Post
    Electrical woes straightened out. One of the trx's lost spark while swapping handlebars. Switched CDI's, spark went to machine that previously had no spark. Screwed around plugging and unplugging the harness, now the "bad" cdi has spark, and both trx's are running. Has been bugging me for 2 months. Figured it would be a good time for a picture.
    Sent from my XT1254 using Tapatalk
    Cazenovia equipment? How many are you milking? 30K tranny in the Deere? I would love to buy that 88 in the middle. Nice property.
  2. #317
    6bt's Avatar
    6bt is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2017
    near Syracuse NY
    318
    Quote Originally Posted by atc007 View Post
    Nah, I'm about 30 mins from the caz equipment in Nelson. My neighbors were milking around 75 before they sold out last year. They just raise heifers to sell now. Another farmer does all the land now. This is white country, or used to be when white was still popular.
  3. #318
    Austin, Massachusetts
    1,591
    Tool is a modern day tribute to psychedelics and a higher level of consciousness .......it`s a brilliant work by Maynard ......the artist that did the videos and lights behind stage ......is off the chain .........saw them last year loved it ......did he wear his robocop suit ? .....primal , methodical just a real different approach to a rock show ......i don`t understand why no lights on Maynard ......might be allergic ......i`d go again this year too !
    Totally agree Glam. They're such a heavy band. Its real rock with a backbone, but its trippy as hell. Elements of like a jam band also, i guess. So good. So much larger, in that way, than say a metallica show or even staind. Maynard is a modern day Jim Morrison. Yes, he was in full riot gear, but way out back in the dark. So good.
    Barnett, I saw Filter play a little club called Pearl Street Station in Northampton MA back in the 90's when I was at UMASS. They had live music every tuesday and Thursday nights. I had a buddy that worked the door and would get me in with a wristband so i could drink. They had a lot of old hardcore bands at the time, like Tree, and SamBlackChurch. Anyway, we saw Filter, who's lead singer was the brother of the guy that played the T-1000 in the terminator. He had just been in a motorcycle crash and played the show shirtless with his entire upper body bandaged up. Very good show. One of the shows I always remember from that time. Small venue. Things would get crazy....
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
  4. #319
    1,591
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
  5. #320
    Jul 2012
    Seattle, Washington
    1,543
    I just started up this little mini 2 stroke for the first time in possibly decades. The fuel tank is still being cleaned out, there was some serious rusty scabs in the tank.
    Anyways I need to adjust the carb, it wont idle unless I hold the throttle open a little bit. I cleaned the carb last night.
    This 60cc sounds much like my tri zinger!
    https://youtu.be/gR-DcQDCL20
  6. #321
    6bt's Avatar
    Jan 2017
    near Syracuse NY
    318
    Finally rode this last night. Haven't ridden it in 5 years. Still needs odds and ends..new plastics etc, but at least it's function and not taking up a whole garage bay. New frame, clutch, misc bearings. Frame was bent at an arm mount. Was only supposed to take a month, back in December! Lol
  7. #322
    May 2015
    San Diego, CA
    1,796
    Working on an 04 E46........installing a new water pump, radiator, expansion tank, etc. A couple of connectors were extremely hard to remove and since I've never worked on this type of setup before.........is there some lube or something I should coat anything with? Silicon grease? Anti freeze? Nothing?
  8. #323
    Mexico
    9,016
    Dish soap works great as assembly lube.
  9. #324
    Jan 2013
    minnesota
    5,911
    Well I can't view most photos on the site because I guess the sites owner thinks I might do something "bad" with them although I can't for the life of me figure out what that might be. Anyway, I do not use silicone on anything except for some spark plug boots because it just seems to get everywhere and it also prevents paint from sticking, and since I do a amount of painting, I can't have that stuff get on other parts. If it is something you want to come apart easily again like a carb in an intake boot, you can use plain grease. I often use old school green or white grease. I just used grease 2 days ago on the intake boots on my Toyota 4runner because it took me 20 minutes to pry them all off and I knew I would be removing them several times over the next few days and it now takes me less than 30 seconds to either remove or reassemble them. WD-40 also works decent or just regular engine oil etc. The liquid soap El Camexican mentioned works for assembly and I use it on some parts, however, my experience with it is that it dries up quickly so the parts can be difficult to remove again but because it tends to loose its lubricating qualities after a short time, it is great to use when installing tires and I have used it for that purpose on some tires since around 1970.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
  10. #325
    Apr 2002
    s.w. michigan
    6,498
    Margarine (fake butter) is a heck of a good cheap anti seize.
  11. #326
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by jeswinehart View Post
    ...and your parts will be tasty too!
  12. #327
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    ... I Can't Believe It's Not Anti Seize!
    Attached Thumbnails Attached Thumbnails I Can't Believe It's Not Butter Original Tub Image.jpg
  13. #328
    Mexico
    9,016
    He's working with rad hoses guys. I don't think anything long term slippery is a good idea. Dish soap or hair spray is the way to go on something you want to seal up.
  14. #329
    May 2015
    San Diego, CA
    1,796
    Ok......I used Joy dish soap.
    This one was a complete b!tch-whore to get off......the second pic. After a tiny amount of joy it slide on nicely. Just waiting for the expansion tank then I'm done with this mofo!!
    Old cars are easier to work on.
  15. #330
    Jan 2013
    minnesota
    5,911
    ...b!tch-whore... ...mofo!!
    Wow, knappy...tsk, tsk, tsk. Now you will have to be punished!
