Page 279 of 312 FirstFirst ... 179 229 269 277 278 279 280 281 289 ... LastLast
Results 4,171 to 4,185 of 4679
  1. #4171
    Arkansas
    2,447
    Why do I need rabbits you may be wondering? .
    Aren't those things illegal?
  2. #4172
    Arkansas
    2,447
    Quote Originally Posted by Scorcher View Post
    The trailer parks there look different from ours, but at least it looks like they have the broken down vehicles scattered about.
  3. #4173
    Mexico
    9,014
    Man-made fresh water reefs are very cool. Come back next summer in your scuba gear and collect $500 worth of jigs and lures that will be hooked to it lol!
    It sucks to get old
  4. #4174
    May 2015
    San Diego, CA
    1,796
    Figuring out why the RV won't start.
    I thought it was a low battery so i gave it a full chanrge then........"click..click..click". Installed known good battery ...."Click..click..click". I thought it might have been the starter so I had Autozone warranty it out for me....."click..click..click".
    I dug in a little deeper only to see ugly cables.
    Also the ground seems week.
    Sorry Autozone
  5. #4175
    Arkansas
    2,447
    I know the first thing most people go to is checking the battery voltage and that's not really useful because a bad battery can still show good voltage. Not that's how you do it, but I've noticed that a lot.
    Old, clunky carbon piles aren't practical for a lot of things anymore and most people would just ruin something by using them anyway. They certainly aren't portable for something to always carry on the vehicle for roadside diagnostics.
    I bought one of these modern testers a few months back and it's been awesome.
    https://www.ebay.com/itm/22420682099...3ABFBMqp-qivxf
    It even does basic waveform testing and would show a bad alternator diode. There's a start test, last saved test (stored in device), motorcycle battery selection, and it's updateable. When I go on trips, it fits in the tool bag or glovebox. Fast, accurate and has plenty of functionality in a compact size. The build quality is good and the clamps have the sensing portion separate from the main clamp body so they'll read more accurately.
    The other thing that's of superior help is a voltage drop test using a multimeter or plain voltage meter. A resistance test (ohm) is practically useless because one strand of wire in a cable is all it needs to pass the test, but the cable won't carry current and is actually bad.
    This is my first choice when diagnosing questionable cables and connections. It doesn't require disassembly of the circuit and only the most basic of electrical tools are needed. Although a basic voltage meter will work, a PowerProbe can be a huge benefit because of the long leads and built in voltage meter.
    This is pretty good video showing how a voltage drop test works.
    https://www.youtube.com/watch?v=APLic9F7ZsA
    PowerProbe, this is the standard one: https://www.powerprobe.com/na/en/pro...t/308EbfcE6f63
    It's incredibly useful. One of those tools that if you don't already own, you'll wish you would have much sooner.
    They're on the expensive side but they'll save minutes to hours of work the first time you have a more complex issue to diagnose.
    Edit: Here's a couple more voltage drop test video links
    https://www.youtube.com/watch?v=3xjLtg3FLoA
    https://www.youtube.com/watch?v=WMXENKujYtc
    Last thing is about making your own cables, because unless you're replacing OE with OE, if they're even available, you'll either be using some ill fitting generic cable or making your own.
    I've used one of these terminal crimpers and they're pretty good. Maybe not this exactly one, but you get the idea.
    https://www.ebay.com/itm/11380755658...3ABFBM2sDljPxf
    The other thing is buying battery cable in bulk and getting the good stuff. Stay away from the cheaper copper clad aluminum cable and get the good stuff from the start. The copper clad will work OK for a while but once the cladding is compromised the aluminum wire will deteriorate very quickly and loose performance to the point of failing.
  6. #4176
    Aug 2016
    East of Worcester ma
    1,355
    Spent the last two days (2-3 hrs a day) The truck hit 80,000 miles. Time to do brakes- all four wheels+sway bar bushings and end links. My body is sore today i'm not as young as i used to be......But it's done.
    Going on a road trip in two weeks so i had to refresh some things. One end link was snapped off (pot hole) recently.
    Also removed the bed liner to find about 5lbs of dirt/sand- re-installed it but i will need to check it more often-i would like a spray on liner but in my line of work the liner actually does do its job i guess. The 2016 silverado has treated me well, looking like doing the front struts/shocks is next in line though(getting crusty) new rear shocks last yr-
    Alright back to work, hope everyone's doing well.
    shep
  7. #4177
    Jan 2018
    California
    111
    From barnett
    "I went slumming today and bought yet ANOTHER honda 3 wheeler, even though I told myself I wouldn't after I sold the last one. I couldn't tell what size it was in the photo on my phone, and the ad didn't say. I figured it was a 90, and when the seller called me back, he told me it was a 125, AND that it even ran and shifted, AND the electric starter even worked, I told him I would take it, and was lucky enough to be able to talk him into holding it for me for a couple hours while all the other sharks were trying to buy it from him. Paid a whopping $500.00 for it, so take that knappyfeet!"
    Not sure what I will do with it, but I will likely add it to my rental fleet and try to rent it out at first, although I am a little worried about the notorious shft spring boss breaking off.
  8. #4178
    May 2015
    San Diego, CA
    1,796
    Quote Originally Posted by rpeters View Post
    From barnett
    Nice find Barns.
    You snuck a fast ball by me......savor the moment cause it sure won't happen again.
    King....thank you for the info.
    I've never made battery cables before......I want to try it. Can't be that difficult.
  9. #4179
    Jan 2018
    California
    111
    Nice find Barns. You snuck a fast ball by me...
    oops, too late...bought this 2008 Suzuki GZ250 a few days ago in near showroom condition with only 3k miles AND a full tank of gas (now valued at over $32.00 ) , for a whopping...wait for it...$900.00.
    Don't worry though, I know I can only celebrate for the moment because the "Wolves are at the door!", so I need to remain ever vigilant.
  10. #4180
    Arkansas
    2,447
    Maybe I got the home AC to work for another summer. The outdoor unit ceased functioning at the very end of last summer and I just got around to looking at it a week ago.
    The contacts were rough looking, but the solenoid was still functioning. The way they are constructed allowed me to completely disassemble them for a thorough cleaning.
    The start and run capacitors for the compressor were toast. The numbers were still legible on them, but the original paperwork was inside the unit housing and in great condition which had a part number list. All the diagrams/schematics were in the paperwork too; lucky me.
    I replaced the switching relay because the whole system is about 30 years old. That and the capacitors got it running again. What, if any damage or wear to the compressor or motor is yet to be seen, but I'm not equipped to replace the compressor and evacuate/charge the system. If that goes out, it's a phone call.
    I may replace the fan capacitor to give the unit every fighting chance of lasting through another summer.
    I was able to employ the use of my Ames (Harbor Freight) multimeter.
    https://www.harborfreight.com/electr...ter-64017.html
    It has a capacitance test function, which made diagnosing the bad ones very quick and safe. The new ones got tested too and one was spot on and the other a good bit over specification which isn't really a bad thing. I wrote the installation dates on them, so if they go out before the rest of the unit, I'll know for certain.
    Yea for self home repair and earning myself a beer (or six) later tonight. Also, hooray for all the parts showing up today.
  11. #4181
    May 2015
    San Diego, CA
    1,796
    You win......I don't want to play no more.
    Did you fire up the DeLorean and go back to 2017?....... because that's prepandemic pricing.
  12. #4182
    Connecticut
    1,605
    Check this company out. I find you can't buy and make your own for what they offered. You pick AWG, terminal ends, etc. They ship quick and don't charge excessive for freight. USA based
    https://www.batterycablesusa.com/
  13. #4183
    Jan 2018
    California
    111
    Cmon' don't give up so easy!
    I picked up this nice 1994 Virago 535 with only 2,224 miles on it, in De Luz yesterday for $1350.00.
    Shop till you drop!
  14. #4184
    Mexico
    9,014
    Shop till you drop!
    Barns let’s you use his trailer?
    So how many of these “Barne” finds (See what I did there?) actually have working brakes at the time of purchase? I figure with so few miles most of the calipers would be locked up.
    It sucks to get old
  15. #4185
    Jan 2018
    California
    111
    I'll ask him about the brakes tomorrow but from the ones I have seen him buy the brakes usually work and he just has to fix the carbs and put new tires on them. The last 4 he bought had the original tires.
    He lets me use his trailer and his truck but I rarely need it.
