Frpm barnett
"Oh I always change the brake fluid regardless, I just don't run into stuck or leaky calipers or masters very often."
The brake fluid below still performs well when it gets moisture in it, and feels less spongy than Dot3, 4, and 5.
"SRF is used throughout Formula 1, Grand Prix and Superbike racing. SRF is a polyglycol-ether based DOT4 fluid compatible with all DOT3, DOT4, and DOT5.1 fluids. With a dry boiling point of 590F (310C) on par with the other fluids, it excels with a 518F (270C) wet boiling point. Even as the fluid wears and collects moisture it exceeds the boiling point of DOT5 making this exceptionally resistant to vapor lock in all conditions. It’s compatible with all ABS systems, and all seals, rubber and materials used in braking systems designed for conventional polyglycol brake fluids. Exceeds US FMVSS 116 DOT3 and DOT4, SAE J1703, ISO 4925 and Australian standard 1960 Grade 3."
