Page 312 of 313 FirstFirst ... 212 262 302 310 311 312 313 LastLast
Results 4,666 to 4,680 of 4686
  1. #4666
    May 2015
    San Diego, CA
    1,800
    Picked up this lap timer/GPS for my XR1200. It is so early 2000's but so cool.
    Any cell phone will probably have an app that will be superior to this device...... but it's not the same.
    Will probably mount the GPS antenna to the rear tail and route it through to the front. It's got a 6 ft cord.
    I like Koso devices
  2. #4667
    Arkansas
    2,447
    I've seen that brand before, but don't have any experience with their products.
    What's the accuracy of the GPS? I don't know what the average phone has for accuracy, but all GPS devices aren't the same. Like GPS units for scientific data and construction are more accurate than consumer grade devices, but they're also much more expensive.
    I figure if it's for lap times, it has to be pretty accurate.
  3. #4668
    May 2015
    San Diego, CA
    1,800
    I don't know the accuracy. I haven't used it yet....other than hooking 12V to it to see it on
    It can learn a course/track/route, etc. For my sake just remembering a trip up the mountain or your favorite rip area.....that should be nice.
  4. #4669
    Arkansas
    2,447
    Attachment 271848
    Clearing up some brush
  5. #4670
    Arkansas
    2,447
    I do a bit of vehicle mechaneckn here and there, on my own terms, choosing what I work on.
    I just finished up another GMT400 and there are some serious realizations needed when working on these early electronic fuel injected pickups, and what it means for the future of new vehicles if they happen to still be on the road in 25+ years.
    Because I pick and choose what to take in, I have customers who just want it fixed, with quality parts, without trying to nickle and dime the repairs. That's the only way I can tolerate working on the older vehicles, but that's not even close to what the majority of uneducated owners expect, and there's some serious wake-up calls coming in the near future.
    To make it short, when these pickups have fuel system issues and there's any rust in the tank (metal tanks the owners don't keep near full), anything short of replacing and rebuilding the entire system is extremely likely to be nothing but a patch, and there will be more problems. Basically, a waste of money and time, and a big headache for everyone.
    One and done, if the tank is ok, new fuel pump, all rubber fuel hoses replaced, rebuilt throttle body with NEW injectors. If the tank is rusted, that needs replaced (It's cheaper to replace than try fix), and ALL fuel lines, from the pump to the throttle body.
    A money saver is they only have two injectors, but they are $100 apiece. Of this post, all the parts are available new, so it's not an issue yet.
    I've yet to see one that had good brakes and the overwhelming majority of the time the brake fluid looks dark like engine oil. The system has been seriously neglected and these have an early, very basic ABS system, which is pretty much useless anyway. I won't be removing the ABS on someone's vehicle though, just won't do it, won't take on that liability. So if that's shot, dig in the pockets a little deeper.
    To stand a chance of getting the neglected and aged brakes working as good as possible, the first time, it's already a given the hoses need replaced. Every five years is a good idea, but I guess ten isn't too bad. When the hoses go bad, they usually cause the brake on that wheel, or both rears to lock up. It's much less common for a hose to blow out and loose the brake/s.
    When the fluid looks like sewage, full stop, let the customer know it's going to need everything replaced, with a maybe on the hard lines. New wheel cylinders, shoes, hoses, master cylinder, calipers, pads, and turn or replace drums and rotors. This is the reality of neglect. If the fluid was flushed every two years, this wouldn't be an issue, but I don't know a single person who dose that maintenance. Brakes are arguably the most important part of a vehicle, even horse drawn carts needed brakes, but people cannot be convinced to spend a little money every couple of years to prevent a large bill down the road. Not mentioning whether they value their life or not, because bad brakes tend to wait to rear their nasty little head during an emergency stop, not sedate driving. Mountain driving will quickly expose water saturated fluid, as it boils and the pedal goes to the floor. Brake fluid is hygroscopic, it absorbs moisture and that lowers the boiling point of the fluid. The higher the DOT rating, the quicker is absorbs moisture, with some exceptions for certain products. DOT3 will generally last longer than DOT4, and a lot of everyday vehicles now are using DOT4. That's just a tradeoff for higher performance brakes, or at least a slightly higher performing fluid.
    Anyway, when these neglected systems need repaired, the only way to do it right, is to do it right. Fortunately, most of the parts for the GMT400s are readily available and since the pickups are relatively simple, there's fewer parts than newer vehicles and at lower prices. Still, rolling one of these old pickups into the shop can easily cost thousands to drive it out, and that's not large single components like engines and transmissions, that's fixing the other systems that support function.
    Most of these aren't worth the money to put into them, except for a small group who appreciate them for what they are, and prefer to keep them going instead of buying something newer. They are a very popular platform with those people, and they are pretty simple and dependable vehicles, if cared for.
    The one I just got one repair session done with, and have some more to do later, but it's fiddley stuff, like recalibrating the speedometer, looks like it's no more than five years old. It was a one owner and garaged all it's life, but it sat a lot, low mileage. That was about a $2,000-$2,500 bill so far. The decade old tires need replaced, but he's putting new wheels on it too, doesn't like the stock ones (I do).
    I got it lined out, then as soon as the owner got in it, it had issues starting. Sticking injector or something else, but these tend to have injector issues when old, even if it's just a terrible spray pattern. Don't know yet, but the process continues, after I got paid. Totally sucks, all around, and certainly aggravates me, but I'm not dealing with some rando public vehicle and they know how I work, so there isn't some yelling customer in the shop to deal with.
    As for newer vehicles, people aren't going to be able to afford to keep them on the road much past warranty. When headlight assemblies are costing over $1,000, instead of a $10 bulb, when it's essentially a computer on wheels and vehicle settings are through a touch screen, that won't be available new in twenty years. When the software isn't available from the manufacturer anymore, because it's behind a paywall even now. It doesn't even matter if there are people who can repair the complicated electronics, people aren't going to pay what that ability is capable of earning elsewhere. Maybe we'll start seeing hodgepodged TEMU tablets in lieu of the factory screens, taped to the dash, just so the vehicle will function, as a vehicle, and not a home entertainment system and massage chair, on wheels.
    Mechanics already know this, they see where it's going, but it falls on def ears. I think there's going to be a lot more motorcycle and scooter sales in the future, because that'll be the only new vehicle people can afford, and they can't afford a 10yo car, can't afford the repair cost or unavailable parts. Heck, even with a warranty, owners are still getting screwed, still making payments on car that takes weeks to get back, maybe even longer. Techs struggle to stay up with the ever changing vehicles, don't get the benefit of 10yo platforms that have been time tested and problems known, and common parts that can be stocked instead of ordered, if they're even available. Shops are being screwed by warranties too, but that doesn't fit the narrative of the 'shops are bad' crowd.
    The main thing is, old or new, there is no free lunch and that's going to be only a saltine cracker in the near future. The people who refuse to be hooked into expensive, financially damaging, lost money of lifetime payments to a large corporation are going to have to figure something out pretty quick. Start taking exceptional care of the vehicle they already own, or planning to downsize to two wheels, powered or not. They'll have to get their lifestyle in order to suit their transportation options. 15-minute city?
    Maybe spend a little, take some mechaneckin classes, buy an older vehicle, repair and properly maintain it. May as well be money in the bank. O'reillys has automotive courses, even does them in person, but those may be only for current techs, not remedial. Trying to study random Google garbage isn't a good idea, need professional instruction, but it doesn't have to be for years or cost a whole lot, there are options. If not going to work in a shop, it doesn't need a diploma attached. Basic code readers and even some more affordable bi-directional scan tools are within reach of many people's budget now, but those don't fix vehicles, only give information that needs interpreted.
    Stay away from anything OBD-1 though. Too old and even the old diagnostic equipment is still expensive. I think that's anything 1995 and older. I don't imagine many people are looking for a 30+yo vehicle though. 00-10 or so was good years for a lot of vehicles. Not too much of the infotainment junk and mostly buttons to work the functions, few/small/no screens or deeply integrated systems. VVT came into play too, so no EGR valve and associated piping to mess with, and no pumps. Bulbs instead of whole lighting assemblies. That little bump in the parking lot just requires a $40 housing, not a $1,000+ assembly. Not having to tape a flashlight on the front to just avoid a ticket or use a credit card for what should be an inexpensive repair.
    I'd like to see more people out of the new car trap. Wheels are not freedom anymore.
  6. #4671
    Arkansas
    2,447
    The joy of cats, they kill everything they can.
    Ours are always getting birds, mice, rats, and moles. There's the frogs and lizards too, and always terrorizing the skinks during their mating season. Tonight, I watched one of them chasing something in the dark, congratulated her on a good catch, then seen it was a small rabbit. Ugh. It's not as bad as when a dog ripped the entire skin from a live rabbit and seeing it suffering, but still.
    The other cat, as soon as I said 'There's enough for both of you' she went following to get some. I just fed them some tuna this morning. Hungry, vicious creatures.
    The circle of life, I guess, but they're not putting a dent in the foxes, coyotes, and bobcats.
  7. #4672
    May 2015
    San Diego, CA
    1,800
    They are house payments. Even after 30K down you could still be at a monthly payment of $1500 for some Kings Ranch or Raptor.
    I do miss my old 93. I practically gave it away after my son incurred some damage to the drive train after a minor collision. I guess I was using that as an excuse because I was sick of the 305 it had in it....it was a tired dog with those tires.
    There's one for sale locally for 7K with 300,000 miles and painted purple. I'll pass.
  8. #4673
    Arkansas
    2,447
    Was that a Baywatch set truck? I'm joking, but I can see it.
    I know a lot of people would be drooling over that truck today. Like you said, the 300K mile one for sale, for way, way too much. That's the common theme now, worn out and dreaming, needing $15k or more just to bring one back to dependable, because of all the deferred maintenance. Sounds expensive, but that would have been less than $500 a year for maintenance since new. Or, less than $45 a month. Much easier to keep up than catch up.
    You're right about the 305, especially a TBI version. Heck, the previous 305s had a four barrel carb, and I think that's all every 305 ever got, no two barrel versions (except the TBI). Maybe that's the Olds 307 I'm thinking about. Anyway, that would have needed 4.56 gears just to feel peppy. I worked on a 305, C2500, LWB with something like ~3.52 gears, maybe ev en something nuts like 3.08. That combination made no sense, wouldn't be good for pulling much of a trailer or even hauling much. Dang 3/4 ton is a whole lot heavier than a 1/2 ton to start with. Back when a lot of trucks came with an inline six, those nearly always tended to have lower gears to make up for the power difference from a V8. 3.73 was real common.
    Those GMT400s had a nice clean look though and small thinks could really change the look of them. Kind of like a nice blank slate. The 90's custom paint schemes...were a bit over the top. Too many sideways license plates on the tailgates too, and terribly installed roll pans. I'm having flashbacks.
  9. #4674
    Las Vegas, NV.
    2,520
    Oil & filter change, and fuel filter change, on the Dodge Ram 3500.
  10. #4675
    Arkansas
    2,447
    I picked up enough brake fluid to flush most of my vehicles. I'm finally going to order a pressure bleeder before I get started. I've used them in shops, but haven't bought my own. They're pretty affordable now.
    Last truck I done had me pretty sore the next day, with all the squatting and kneeling, up and down, back and forth, flushing them myself, the old way. I use a ratcheting load bar, Harbor Freight one, to hold the pedal down as I bled, and it works like a charm. It's pretty bad at being a load bar, and I used it once for that then put it away, before later finding it's better use.
    I don't like to use vacuum to bleed. For one, I have to pull the bleeders out and Teflon tape them, to prevent pulling air past the threads. Same goes if using the catch can, one man method, got to tape the bleeders.
    The problem with pressure bleeders is they work great on most master cylinder reservoirs, EXCEPT, the square plastic ones, like GM used, and that's what I'm about to do. They have to be on perfectly, to prevent making a giant mess, and it takes some trial and error to find the sweet spot. Not too loose and not too tight. The plastic reservoir bleeder adapters are pretty much junk, including the Mityvac brand, and the metal ones used to be expensive, but they're not now. It's bad enough the plastic reservoir will flex, so don't want the adapter flexing too. They go on with two chains, four J-bolts, and four wingnuts, so it's juggling several things, moving around. Not like the reservoirs with twist-on caps, which are straightforward.
    Making any mess with brake fluid is the worst mess I can make, because it damages paint.
    The pressure method is fast and easy (once it's set up). I can push the old fluid out quickly and don't have to worry about keeping the reservoir full because that's done automatically. Set the vehicle up on stands, pull all the wheels off at once, and go to town. A lot less of up and down and back and forth, so a whole lot easier on my body. Actually, I'll just roll up a stool and sit down while I do it. No bending over while on my knees and being sore in the morning.
    Getting a new tool is exciting.
  11. #4676
    May 2015
    San Diego, CA
    1,800
    Too hot in Vegas to do anything but watch old episodes of Rockford Files & kick it at Sams Town.
    Unless your garage is cooled of course...... but then your a slave to NVenergy.
  12. #4677
    Arkansas
    2,447
    Attachment 271856
    I've been waiting to share some pictures until I got started on some of this, but it's done got hot outside and projects have slowed to a crawl.
    Several months ago, a very generous member contacted me and said if I pick it up, I can have it. A 500 mile round trip for some gifted ATC parts? Oh yeah!
    A couple 350X frames, 200X frame, some swingarms to go with, a few forks, a couple 350X engines, a few fuel tanks, oil coolers, boxes of small parts and whatever else I'm forgetting.
    With some parts I already had, I should be able to build something on a relatively small budget, and there's several combinations possible. Auto-X, ATC300EX, not sure at this point, I need to rummage through what I have to see the condition, because I haven't touched a lot of it in years, but this haul has encouraged me to bolt some of those parts together and use them.
  13. #4678
    Las Vegas, NV.
    2,520
    Nope, no air conditioned garage here, and even if it was, the truck is too long to get it completely inside. Just getting into the shade of the garage, and out of the sun, it’s noticeably cooler, but yeah, still way too hot. It’s a struggle for sure. When it’s a tedious project, that I’m working on, sometimes I can’t muster up the will power, to go out and work in the heat, and projects will get put on hold. Other times, and for required maintenance like this was, I just have to suck it up and go do it. I know when I’m done, I get to go hose off in the back yard (no swimming pool ), and that feels so nice!
  14. #4679
    May 2015
    San Diego, CA
    1,800
    Attachment 271856
    Cool score.
    If you come across a Goki for the 200X let me know.
    July is tuff.
    I know a guy there who has a split system for his garage. It works ok/well until you open the door and take the car out.......all that cool air bye-bye.....especially bringing in a hot car. Still it allows you to be in the garage & not miserable so that's good.
  15. #4680
    The Open Road
    4,736
    When my 97 Softail crapped out 2 years ago, I went to see about a used bike at the dealership with a brand new 130 crate motor in it. Didn't like the loan terms because the bike was a few years old and ended up walking out with this thing. It's definitely an impulse buy, but I had plans to ride the US for a month or so and needed a solid ride. After a 500-mile break in, I rode it to Navarre FL straight through. 8 hour trip that turned into 12 hours after hitting Birmingham AL and Montgomery AL traffic. The trip home was 10 hrs thanks to me trying to thread the needle in between two massive thunderstorms somewhere in North Alabama and being too stubborn to stop because I was already soaked to the bone.
    When I got home from that, I took the MSF course, so I would finally have an MC Operators license after riding for 33 years
    without one.
    Anyway, I've only put 7K on it since Nov of 23 thanks to working constantly. Tomorrow I'm going to just point it in one direction and ride until I get tired and then turn around and come home. Maybe I should quit my job for a month so I can put some real miles on it and justify the price tag.
    Sent from my SM-S918U using Tapatalk
