Page 91 of 312 FirstFirst ... 41 81 89 90 91 92 93 101 141 191 ... LastLast
Results 1,351 to 1,365 of 4679
  1. #1351
    Jul 2003
    indiana
    892
    I'd guess 120 ish. Yamaha is about the same, not really geared for super high speeds, pulls like a freight train up to about 110 tho.
  2. #1352
    May 2016
    OH Canada
    1,102
    This is where I'm at with it now. It doesn't ohm out to specs right now and who knows on the rectifier but more than that........I'm I thinking of just getting a used one "guaranteed" off eBay for $100 - $150. Seems easier at the moment.
    Attachment 249205
    Attachment 249206
    Attachment 249207
    I hear you. Brushes look good (still lots of meat). I know it is too late for this. BUT. I would of given a light sanding on the brushes and contact area on the armature and try it. The inner contact will always arc more. I know I work in the onroad 1:1 field. These things you are working on see some nasty conditions.
    '83 200X
  3. #1353
    Aug 2016
    East of Worcester ma
    1,355
    Just finished pulling the inner rubber core part out of a mold. It was like mounting/removing a atv/c tire without tire irons (not fun)
    I may have to mix up some plastic later (oem in picture) to be continued:
ID:	249424 Click image for larger version.
    I guess i could make headlight shroud shaped ice cubes. Ha
    Shep
  4. #1354
    May 2015
    San Diego, CA
    1,796
    Quote Originally Posted by Rob Canadian View Post
    Your right on the inner one.
    I cleaned the comutator and the brushes then I polished. When I reinstalled it worked for awhile then stopped.
    The nice thing is the rectifier/regulator is built into the generator. All of 2 wires and a fuse makes up the entire charging system so my thought was a failing/failed rectifier. I even bypassed the wiring harness and still nothing.
    I ordered a used one.
ID:	249427 Click image for larger version.
ID:	249428 Click image for larger version.
  5. #1355
    Gold Hill, OR
    1,295
    I'm on the Big Beach in Maui.Click image for larger version.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
  6. #1356
    Aug 2016
    1,355
    I was going to edit my other post but:
    I was about 50grams short on my mix but now i know to add twice that!!!
    The headlight brackets will work great, jeswinehart your right about the venting (have 4 now) i think that’ll do it, shall see.
    Ya i know its green- i’m just playing w/colors...
ID:	249452 Click image for larger version.
ID:	249453 Click image for larger version.
ID:	249459 Click image for larger version.
    Just showing progress, yay
    Shep
  7. #1357
    May 2015
    San Diego, CA
    1,796
    Shep
    That looks really nice shep......... very impressive!
  8. #1358
    Gold Hill, OR
    1,295
    That looks nice ....whats the water temp ?
    80 water. Pretty warm day with a light breeze- 84.
    Joker 90
    1981 Yamaha YT125
    2005 Yamaha YFZ450
  9. #1359
    Apr 2002
    s.w. michigan
    6,498
    Shep
    Nice !!! I learned about pre pours on the X mold,,,, a method we now use on any trouble area or anything involving pegs or protrushions.
  10. #1360
    Aug 2016
    1,355
    I figure i could always make larger vents if needed to fill a spot, but yes a pre pour i can see helping on certain things. I hope its not needed here. This next one (yup green) i added 80grams more mix, it filled up/squished it down and just a little came out the vents/ from what i can see it looks full, i’ll find out in about an hour.
    I have to find me a big heavy book instead of these items.
    Was planning on a white one but reached for the green instead, oh well.
    Edit: much better, this one filled out great. Click image for larger version.
ID:	249462 Click image for larger version.
    Thanks for looking, i put pics of a red and a white shell in the mad scientist section- easier to find later on that way i guess.
    Shep
  11. #1361
    May 2015
    San Diego, CA
    1,796
    2 down and 2 to go.
    So far I've needed to grind 2 bowl fasteners off, broke 1 jet, 1 needle cap, striped 2 JIS fasteners and broke 1 Allen wrench but.........it's all good!
  12. #1362
    May 2016
    OH Canada
    1,102
    I picked up this yesterday. Not that I needed one. It was BO. Not running. Went up to see it. Took it for $75.00 not running.
    Drained the gas from the tank and carb. Installed new gas. 2 pulls and it fired up. Runs great.
    '83 200X
  13. #1363
    Aug 2016
    1,355
    Well i was going over the bike for a ride in NH tomorrow, a few loose bolts, topped off the oil (everything is ready)!!!!
    Then as i was loading it i figured hmmmm i’ll check the brakes.. their gone nothing left, (china pads) replaced them in the late fall and this bike doesn’t see many miles. So i go in the house search around and find “more” china pads luckily. So i have an hour of daylight to swap brake pads front+rear. Fun stuff!!!
    I guess its good that i checked them but maybe its time i invest in better pads! Was having a great day until now.
    (Just venting)Click image for larger version.
    Edit —- brakes done, front pads are snug (not tight) only slight rubbing on the rotor but hopefully will break in ok, im thinking they will. I hope
    Shep
  14. #1364
    I think everyone gives those pads a shot at some point. I watched Tecate Dan blow right through a brand new set in one ride. See you bright and early Shep!
    May 2015
    San Diego, CA
    1,796
    Bad fuel pump............. awful timing.
