Page 98 of 313 FirstFirst ... 48 88 96 97 98 99 100 108 148 198 ... LastLast
Results 1,456 to 1,470 of 4692
  1. #1456
    May 2015
    San Diego, CA
    1,801
    This has got to be the weirdest looking tank liner ever.
    Still working at it periodically as it really is difficult to get off...... and to preserve the original finish at the same time.
    it's like an 1/8 of an inch thick and so porous/spongy looking it's hard to believe it thoroughly covers the tank........weird
  2. #1457
    Mexico
    9,019
    Correct me if I'm wrong, but you don't even know if that is sealant, right? Maybe the guy's ex got upset when she found a long dark hair in his b*tch lid and dumped something nasty into the tank? Was the petcock screen clean?
    It sucks to get old
  3. #1458
    May 2015
    San Diego, CA
    1,801
    I'm a Caswell Sealer virgin so I hope my first time is a good one.
    Your right.....I really don't know if it was a sealer but it coated the entire tank.....which led me to believe it was......which along with you I never heard of it back then.
    What I've been doing is using lacquer thinner and placing the tank in various positions as to help loosen it so I could pull it off. But it seems to have caused rust everywhere so I will have to deal with that prior to the Caswell. There are some areas way in the front that will have the old sealer in it forever as it just seems impossible to clean entirely.
    This was how clean I got it to before I had to use the lacquer thinner method to loosen things up over time......now its like i put saltwater in it.
    Last edited by knappyfeet; 02-19-2018 at 05:53 PM. Reason: petcock screen was clean
  4. #1459
    Mexico
    9,019
    I’m guessing used tanks are few and far between?
    It sucks to get old
  5. #1460
    May 2015
    San Diego, CA
    1,801
    They are out there but not as good as condition is this one......especially with no dents and a decent 30 year old original finish.
  6. #1461
    Aug 2016
    East of Worcester ma
    1,378
    Well, hopefully with the better weather coming i’m going to get back into casting aluminum. My first project is doing front master cylinder covers- “but” i need a plastic mold first. The inner core and two outer split mold pieces, i’ve got the core done. When i’ve finished the plastic mold it will be converted to aluminum, drill/ tap for a nipple and use a mini grease gun to inject rubber.(well Maybe) venting could be interesting though.
    Havent really figured it all out yet- but i know mine at 30yrs old are nearing the end of there life so....
    Used the very last of my mold rubber to make a headlight pin mold/ just making a few for myself. But this mold works great. Kind of complicated mold but im happy w/result. John u did /tried these in the past i think i read but i couldnt find it again but i know its there somewhere. Click image for larger version.
ID:	250600 Click image for larger version.
ID:	250601 Click image for larger version.
ID:	250602 Click image for larger version.
ID:	250603 Click image for larger version.
ID:	250604 Click image for larger version.
    Thanks for looking,
    Also put an order in for more headlight shell plastic yesterday. So i can play with those again.
    Also going through a nasty head cold at the moment- yuk
    Happy saturday!!!
    Shep
  7. #1462
    Nov 2015
    Davenport iowa
    1,144
    Got spark on a tube frame 90 barn find this morning.
    Getting it ready for a flip..
  8. #1463
    Mar 2017
    Oklahoma
    77
    Organizing. Sold one and it’s buried the deepest.
  9. #1464
    Scootertrash's Avatar
    In the sticks
    4,638
    Preppin' wheelers for this afternoon. 6-8 inches of snow predicted this afternoon thru tomorrow morning. Got about 6 Thursday night. Bonfire is ready to light. It'll be tough for the three wheeler with the belly draggin' thru the snow, but I'm gonna give 'er a shot. Wish I had a GoPro.
  10. #1465
    May 2015
    San Diego, CA
    1,801
    Routine maintenance on the Electra Glide was anything but routine today.
    Took me like an hour just to remove that filter......it was on there. Should of took my $65 coupon to the dealer and had them do it.
ID:	250676 Click image for larger version.
ID:	250677 Click image for larger version.
  11. #1466
    Mexico
    9,019
    Did you shoot it with a .22, or a .38?
    It sucks to get old
  12. #1467
    Mar 2009
    new england
    1,391
    Couple hours off this am, gator tear down
  13. #1468
    Jul 2012
    Seattle, Washington
    1,543
    I’m trying to cut some threads on a piece of 15mm round bar stock. It was cutting a little bit at first, now I can’t get it to cut anymore. I’m using cutting oil and going slow, I used a small pick and q tip to clean the die but it won’t cut any more.
    This end came slightly tapered that im working on. The bar measures 15mm, and my die is 15mmx1.5mm. Does anyone have experience with cutting threads?
ID:	250779 Click image for larger version.
ID:	250780 Click image for larger version.
ID:	250781 Click image for larger version.
  14. #1469
    TTown, Alabama, United States
    845
    I don't have a metric equivalency chart only standard but I'm thinking that the stock is too big for the threads you want or the die is stripped....Then again i don't work with metric size stuff much and you may not have to worry about thread percentages and such....eager to learn this myself.
    Last edited by 83ATC185; 03-01-2018 at 05:10 PM. Reason: sorry im no help at all lol
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
  15. #1470
    Jul 2012
    Seattle, Washington
    1,543
    I can turn the bar down a little more, earlier I had to remove a little material to get my bearings to fit. Mabey I should set up my lathe again...lol... I just don’t want to take off too much material. The die and 15 x 1.5 mm nuts came off the slow boat from China, it took forever to get here.
ID:	250783 Click image for larger version.
ID:	250784 Click image for larger version.
ID:	250785 Click image for larger version.
