Page 99 of 313 FirstFirst ... 49 89 97 98 99 100 101 109 149 199 ... LastLast
Results 1,471 to 1,485 of 4686
  1. #1471
    The Open Road
    4,736
    Quote Originally Posted by 3 Wheel Drive View Post
    I can turn the bar down a little more, earlier I had to remove a little material to get my bearings to fit. Mabey I should set up my lathe again...lol... I just don’t want to take off too much material. The die and 15 x 1.5 mm nuts came off the slow boat from China, it took forever to get here.
    Attachment 250783 Attachment 250784 Attachment 250785 Attachment 250786
    https://www.engineersedge.com/hardwa...ead-sizes1.htm
    You probably are still a little big on the OD
    On external threads, refer to the "Major Diameter" section and the "max" and "min" column.
    Max is the largest OD (outside diameter) you should thread at and the min column is the minimum outside diameter for threading. Any smaller than minimum will give you sloppy fit.
    To convert from millimeter to inch:
    Millimeters ÷ 25.4 will give you the inch decimal equivalent.
    Inches x 25.4 gives you the millimeter equivalent
  2. #1472
    The Open Road
    4,736
    On using dies to thread, also be very sure your die is square to the rod you're threading. If I thread external with a die, I'll Chuck it up in the lathe and use the tool post or similar to make sure my die is square to the rod
  3. #1473
    Jul 2012
    Seattle, Washington
    1,543
    I don’t have a real lathe yet, but I did buy the same size tap m15 x 1.5mm. It came with a pilot bit that is 13.5mm. I also bought (8) m15 x 1.5mm nuts for the axle when it’s finished.
    I tried turning the nuts on to the tap to see how they fit, interesting to find that they do not fit. I will remove more material off of the bar to see how the die cuts in the morning.
ID:	250791 Click image for larger version.
ID:	250792 Click image for larger version.
ID:	250793 Click image for larger version.
  4. #1474
    In the pic where you're measuring the die with the caliper, that's not going to give you the diameter. It needs to be measured across the center.
    stoshu is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2011
    winnipeg
    249
    Sitting on a beach in the the Dominican republic. Nope, can't load pictures. If anybody cares go to Sledknawker for the finals of the TLR cup
    My buddy's in third overall this season.
  6. #1476
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by stoshu View Post
    Enjoy!!!! Good luck on your buddy's season. Post up pics when you get back. Start a thread.
    '83 200X
  7. #1477
    May 2015
    San Diego, CA
    1,800
    No pictures?
    Then I'll just imagine it looks like this.Click image for larger version.
    Sent from my SM-T900 using Tapatalk
  8. #1478
    Jun 2011
    winnipeg
    249
    More like this
    Attached Thumbnails Attached Thumbnails 25B2B78E-51FF-4678-BAC1-5E19C0692C98.jpeg
  9. #1479
    Scootertrash's Avatar
    In the sticks
    4,638
    No pictures?
    I'll be in my bunk
  10. #1480
    Nov 2013
    Oxford CT, New Haven County
    984
    im on here, totally ignoring the Oscars! next ill probably break down the pistols and driop them into the sonic cleaner in Honor of all the big shots wearing their orange pins!
  11. #1481
    May 2015
    San Diego, CA
    1,800
    Doing DR650 stuff.
    Someone needs to put Shawn Powell and his new XR400 in their place!
    The charging system hasn't worked since the Clinton Administration.....going to get that working
  12. #1482
    Feb 2017
    Corona CA
    858
    Doing DR650 stuff.
    while you were wrenching I took my dad out in the mud and got mine dirty. [emoji12] ride red and you won’t have these issues. Nice bike.
    Sent from my iPhone using Tapatalk Pro
  13. #1483
    May 2015
    San Diego, CA
    1,800
    HAHA!........10-4
    Ride red.....copy that!
  14. #1484
    Mexico
    9,019
    Making storage space where there wasn’t.
    Hard to believe I moved to Mexico with one truck load of stuff that included a motorcycle.
    It sucks to get old
  15. #1485
    In the sticks
    4,638
    Looks like you need one of these:
    https://www.harborfreight.com/weldin...net-61705.html
    Dang things have gone up in price since I got mine 3 years ago. I got mine for 80.00. My only complaint is that the platform doesn't have room for 2 tanks. At least not yet.....
    Are you a gypsy?
