Okay here are the specifics on the Chassis.
All of the Team BAPP Bikes used Dickson "Sprint" Frames and front Springers. As noted earlier I built this bike the way I would have built it back in the day if I had unlimited $$$ and resources. With that being said I used a Pauter PJ-1 frame vs the Dickson. The PJ-1 was built by Pauter Machine for the PJ-1 Race Team. Not sure how many of these frames were built but from all accounts there were very few. The frame is several inches longer in the front. At least two inches longer out the back and the motor is four to five inches lower and moved forward. It has a very low center of gravity. Excellent for TT and Flat Track Racing.
I did use the Dickson Springer on the front. I always love the springer front ends. They are simple yet effective suspension. I want to personally Thank JWheeler for donating this piece of the bike. I knew way before I started this build I had to have this piece.
We'll start at the Front and work our way to the back.
For bars I have Renthal. They were what everyone ran. I used a "CR" Style Clutch Lever and Perch as well as a "CR" style push button kill switch. The twist trottle is a BAPP 1/4 turn.
The front Hub is an aftermarket Dickson. The front Wheels are Trick Trike Turbine with a Goodyear 21x11x8 Compass. You had to have a Goodyear knobby for the front.
I lowered and used cleated pegs. You lowered the pegs so you would have a lower center of gravity.
In the back I again used Trick Trike turbines. Tires are Carlisle Turf Savers 18x9.5x8. 3" Rocky Wheel Spacers, Axle Boots.
BAPP Chain Tensioner, BAPP 38T Rear Sprocket and a Precision Engineering Rear Disc Brake using a Hurst Airhart caliper.
Finally the Rear Fenders are Trick Trike LowPro race fenders. The tank is a stock Honda ATC90. The rear seat cover is a Saddleman's. I wanted to have a seat cover made to replicate the Team BAPP covers but I kept running into road blocks. Still haven't given up on that yet.
I used "Sunburst Yellow" for the base and added the other traditional BAPP Logo Colors. I did the paint myself. I did have the 'Blue" pinstripe and text add.
Well I think that just about does it for the Chassis.
Next installment will be the MOTOR!!!
DO the Best With What you got !
My Feed back :cool
Ol Deuce
