Results 1 to 7 of 7
Thread: Clutch 200x
    May 2016
    US
    7
    Clutch 200x
    Replaced 1984 200x clutch, finally getting better about letting me engage 1st gear. Is there some secret for it to engage 1st gear after new install? Used a Barnett HD clutch new fiber and steel rings and HD springs..
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Oct 2016
    New York
    118
    If the idle is set to high it will bang into first gear. If you slow down the idle speed on the side of the carburetor it will engage smoothly.
    May 2016
    US
    7
    Greenhaze, it chatters when put in first, will engage sometimes mostly use 2nd. I assume previous owner bent this and it's affecting 1st gear.
    May 2016
    US
    7
    D
    BigRedGrizzly's Avatar
    BigRedGrizzly is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Jersey
    296
    Sounds like you may possibly have a bent shift fork within the transmission. [emoji30]
    Oct 2016
    New York
    118
    Yea hate to say it but it's probably time to split the cases and take a look at the transmission. Also get a new arm, that looks bent, you may be wearing out the new clutch you put in.
    May 2016
    US
    7
    Any members in california that want to rebuild engine for me?
