Hi everyone,
Leaning towards rebuilding this 185s. They are one of my favorite ATC's, but it will need quite a bit. Rear frame where the grab bar bolts is tweaked some. One of the foot pegs is bent, and one of the front shocks are bent. Other than that, it's in decent original shape. The engine looks untouched, has good compression and spark. Tank is solid, with minimal internal rust. Front and rear fender both have cracks that are fixable.
Tires are shot, I've already cut them off. Rims are good enough. Exhaust is solid and will be nice after a wire wheel and high heat paint.
So if I can get the bends out, I will at minimum need seat cover, seat foam, carb kit/rebuild, and tires. If I can't get the front fork tube straight will need to get them.
Or on the flip side do I go all the way and strip it to the frame, paint and new plastics all the way up and new wheels?
Or last option is to part it out to buy more.
I paid $150 for it as is.
Thoughts?
Back story goes as:. A mom took it from her kids cause they wouldn't stay off the road and it sat in the garage for years and years. Then the guy I bought it from got it about 5 years ago, but he never made a serious attempt at getting it running. Pics of when I got it home and after disassembling. So far all bolts have come out easy.
. Unless the rear frame is making the bike drive funny or is making it impossible to mount things leave it alone. Now frame up restoration doesn't necessarily have to be overly expensive you just have to be patient and thrifty with every step. Instead of replacing everything take your time to restore alot of what you already have.
