Hello All
I Recently Purchased a 1983 ATC 185s, and cleaned it up. All of the bones of this unit are really pretty good. After running it for a bit, I noticed some oil Residue on the front part of the cylinder.
My first thought is to check the torque of the Cylinder stud nuts, and then if that doesn't work, that I will probably need to replace the cylinder and head gaskets.
It seems as though the OEM Cylinder gasket is still available, but that the head gasket is not...
Does anyone have a good substitute brand of gaskets, or any other ideas of the possible source of the oil residue?
Thanks so much guys
Bernard![]()
