ok sorry for the long post in advance but having some issues with a transmission. I have two 200x's one that is a basket case and the other that had kick start issues. so I rebuilt one complete engine using the kick start gears on the two trans shafts from on engine to the other that atc runs great no issues. the problem that I am having is that I purchased a used trans on ebay for an 85 and every thing looks the same except the two gears. by the way I am trying to put together the second 200x. my question is did I get a trans for another year or what. I have also seen when doing research that there might be a trans a and b not sure if that's true and how do I tell if that is true.both new gears have the same amount of teeth they are just a little different in width of gear wich causes the main shaft to not turn when case is tightened when case is loose everything spins fine. and lastly I thought most every thing for the 84-85 were the same I know the 83 has some different sprocket sizes in trans. any help would be great just got this crap and it don't fit:
