84/5 200es
Sent from my iPad using Tapatalk
My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
Fixing to pick it up , got some information about it is it a good bike?
Yes, very reliable work platform. Not as sought after as the 250, no rear suspension, but good machines all the same. This looks to be the shaft drive version which is an advantage as long as it's still got oil in the rear end.
This bike needs to bought back to its original glory
Shaft drive or chain?
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
I think shaft
200es was only one year, 1984. In 1985 the 250es replaced the 200es. Prior to '84 the 200 Big Red (as all of these models were known) was a 200e. The 200e had e-start, 5spd dual range transmission, was chain drive and I'm not sure if it had reverse or not, can't remember. The '84 200es was all of the above but shaft drive and had reverse.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Thanks!! I will be going to pick it up this weekend and know more about it
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
The subtransmission is not even remotely similar to that of a 200ES, and the "ears" at the lower rear of the fuel tank suggest that it is either a 185S or 200S item.
I don't know where Pagagould is, but in North America that is a 82 or 83 Big red. It is chain drive.
Guys, that is a 200es, every day of the week. Sure the year is debatable, but that reverse/shaft drive sub assembly, forks and plastic are unmistakable.
