Results 1 to 15 of 20
Thread: 200x front caliper
    Mar 2015
    Manitoba
    98
    200x front caliper
    The front caliper on my 200x is toast! What years of kx 80-85 can I use? Are there any other calipers that you guys have cross referenced?
    Thanks
    Slidell, LA
    4,738
    Why not rebuild it? Rebuild kit is cheap.
    Mar 2015
    Manitoba
    98
    Haha long story the Allen is stripped and the bracket is broken lol
    Slidell, LA
    4,738
    The actual housing or the bracket that attaches the caliper to the fork?
    Mar 2015
    Manitoba
    98
    Everything is finished.
    Slidell, LA
    4,738
    Well that sucks. I believe ytz drew knows what calipers interchange
    Mar 2015
    Manitoba
    98
    Alright thanks!
    Oct 2014
    tn
    110
    I have an 03 kx85 and cr85 for rear as well. Alot better than the stockers. I think I paid 45 for the both of them the car came as the complete set
    the only time I will be easy is when I'm killed by death
    Jan 2014
    Massachusetts USA
    782
    Yup, Kx85 REAR caliper on the Front of the 200x, and the Cr80/85 Front caliper on the Rear of the 200x. Buy each complete with it's respective master cylinder and his, and you have everything you need to redo the whole braking system. The kx rear master cylinder needs a piece of angle iron to adapt it to the 200x frame, everything else bolts up using the original X caliper brackets.
    1985 Tri-Z 250
    1985 ATC250R
    Mar 2015
    Manitoba
    98
    Thanks! But I think I have found a better thing! A brand new break caliper!!!!!!
    Mar 2015
    Manitoba
    98
    Brand new outta the packaging!
    May 2016
    OH Canada
    1,102
    OHHH. Shiny new things...
    Where did you get that sucker?
    '83 200X
    Mar 2015
    Manitoba
    98
    Quote Originally Posted by Rob Canadian View Post
    I've got a family friend who has quite a few trike parts!
    Slidell, LA
    4,738
    Wow that's a first for me.....NOS 200x brake caliper....
    Mar 2015
    Manitoba
    98
    Haha I know I'm amazed that he found me one [emoji23]!
