Results 1 to 11 of 11
Thread: Stumped: Very nice 85' 250ES shifter frozen in place.
    QCR77's Avatar
    QCR77 is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    SA TX
    538
    ive tried researching on here and google as well and cant even find this symptom, let alone the remedy.the bike is in neutral and the foot shifter is stuck in place. im afraid to really put any weight into it as i dont want to break anything.
    now i will say that i had been messing with the shift adjuster between the last time it had been run and now. So while my adjuster bolt is seized in the case and all i was able to move was the lock nut, i have a strong feeling its related to that. its a really nice BR that has never had issues and is well maintained so im hoping its an easy fix.
    i have loosened the lock nut on the adjuster and it didnt do anything. ive also lifted up and bounced around the rear end. with it not being in gear , im not sure how to manipulate anything inside.
    any and all input is very appreciated.
    NEPA
    7,051
    #21 is broken off or worked loose. There are tons of threads about this...
    http://fiche.worldofpowersports.com/...GEARSHIFT-DRUM
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    sweet, thank you. not having any luck with the search yet but will stay at it
    Just take the left cover off and you will find the issue, easy fix...
    Hampton, Virginia, C.S.A.
    2,664
    number 21 would cause a frozen shifter?
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    well i made it this far and no broken bolts. the little collar in the second pic did fall at one point though and im not sure from where
ID:	244231Click image for larger version.
    Austin, Massachusetts
    1,591
    #21 brother. pin is done broked off! Order yourself one, asap. and try and find the broken piece.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    Quote Originally Posted by redsox View Post
    #21 is fine.
    its something in the case. not sure what my next move is with this motor.
    With a 12mm socket, can u rotate the drum?? Pull the plug and spin the motor just a hair back and forth while trying to rotate the drum...
    Whatever you do, do not pull those 3 bolts on the output shaft!!
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Make sure both pins are tight....a loose pin can cause same issue as a sheared off. I can see them in the pic but you need to put a wrench and make sure they are tight and haven't worked loose.
    Jun 2014
    utah
    436
    The other pin is #8 that can cause issues on same schematic.
