YT60 Tri Zinger Carb Options ???
I need a carb for my tri zinger, the stock one is beat and the choke slider is frozen in it. After a quick search on ebay I see a bunch of different aftermarket cheapies.
Anybody try these and which ones are good? Do they come with stock jetting?
Or is there another model carb I should go with that works good on these?
Thanks for the info!
86 350X ::: 85 250R
Projects
350x
Come and Gone
86 350x : 84 250r X2
85 350x X2 : 84 200es X3
83 200e : 78 ATC90
I try not to use the china stuff BUT, a couple well maybe 4yrs ago i bought one from wincycles just to be temporary while i cleaned/soaked the original one. Same thing the choke slide was frozen solid.
Before i installed the china one i replaced anything i could w/oem(jets,rubber parts). You've got a 50/50 shot of the china carbs working anyway so i figured i'd up my odds, and its been running fine all this time.
The plunger is Free'd up on the stock carb but now the orifice under neath is jammed full of crud. Soooo on the shelf it sits.
But beware if u buy china make sure to open the float bowl anyway, there could be packing material inside......
Shep
There is 1 mikuni at the top of that page. I used my stock carbs on all my zingers, they work great.
I have a China carb on both my zingers now and they run fine. In fact just "rebuilt" my Mikuni carb over the weekend cause my daughter had to keep shutting off the gas as it was leaking The new rebuild kit did the same thing the problem must be in the carb itself not the needle so I threw on a Chinese carb and never looked back
//ArrowChat Integreation Code
