Results 1 to 7 of 7
Thread: Portable tachometer????
    Dec 2003
    Germany
    94
    Hi guys me again!
    Just finished my 83`200X Project... gotta do some fine tuning on it but its ready to ride now...finally...
    Ok heres the problem: I just got to the tune up section in my Clymer manual and they tell about a "portable tachometer" when adjusting cam chain... so...what is this? where can i get one...and uhm where does that conect? ( i think it`s a thing to sense the rpm of the machine, if it is so are there any "tachometers" wich i can use when i ride it to? (like odometer))
    Peter from Germany
    P.S.: i will post some pics of my (now) ultra cool 200X tomorrow....
    Shrewsbury, West Virginia
    564
    Yes, a tachometer registers the RPM of the machine. I'm not to sure on how to hook them up but I'm pretty sure you somehow connect it into the stator and into something else and it will give you a true rpm reading. Someone else on here should be able to tell you how to install it.
    Dennis Kirk (www.denniskirk.com) has some portable digital tachs with an hour meter on it too that mounts on your machine. I don't think there is one for the 200x but I may be wrong...I only remember seeing them for newer model ATV's.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    i have a portable tach,, its a hand held guage witha rubber tip that you hold right on the end of the crank ,,, made by stewart warner ,,,, works great,,
    dz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2003
    Langhorne, Pa.
    215
    I think you can get them on ebay or northern tools, I know they have them for the smaller briggs engines which work by vibration? on the head. They also have an hour meter.
    If it aint old I dont want it!
    My feedback thread:
    http://www.3wheelerworld.com/showthr...EEDBACK-FOR-dz
    Current rides:
    Street:
    1989 Yamaha Venture Royale 1300
    Trikes:
    1979 Honda ATC110 sitting winterized
    Jan 2004
    6
    the portable tach consists of the handheld tach meter and reflective tape that goes on the flywheel. when the engine is running point the meter at the flywheel and when it sees the reflective tape the meter will give you the revolutions per minute. hope that helps!
    85 tecate all orig. mint cond.
    88 KX 250 4/SALE
    1950 MERC.TUBBED,CHOPPED AND SHAVED,NEEDS DRIVETRAIN,HAS COMPLETECUSTOM INTERIOR ,BLACK WITH PURPLE GHOST FLAMES 4/SALE
    SOLD 84 tecate ext. swing arm , dg silencer, rebuilt engine , realtors on alum. rims on rear , new fly wheel and stator from rickys. t3 is quick!
    Jun 2003
    South of Rochester, NY
    3,470
    I have a couple 350X Hondaline tachometers.... not sure if they made them for 200X's or not. (NOT for sale!)
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    The portable shop type tachs I've seen go around the spark plug wire or against it and measures RPM by sensing the spark pulse.
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
