Results 1 to 2 of 2
Thread: Plastic weld fenders
    May 2017
    southwest
    Hi guys...I'm new here. I've owned a lot of three wheeler's over the years and just ran across three fixer uppers. My favorite is the 1985 ATC 250SX. On this 250SX the rear left fender is completely cracked off. I'd like to find someone that has the same problem on the opposite (right) side so that I can attempt to plastic weld two bad halves together right down the middle where it is not visible anyway. If I can't find one, of course I'll end up buying new, but I'd like to make this work if I can. Anyone out there with a rear fender in that shape for a 1985 ATC250SX?
    Thanks in advance
    THE OEM SX has the toolbox and most of them are broken. Plastic welding has very little desired results. Sewing them with a tiny drill bit and fishing line works.
    MAIER fenders don't have the toolbox and therefor, don't break like OEM does...
