Results 1 to 14 of 14
Thread: Atc 250r compatible engines
    Apr 2017
    Thunder bay, ON
    19
    Looking for other 2 stroke engine options for a 1983/84 ATC250r preferably drop in no frame mods.
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    81-84 are all the same.
    Jun 2014
    utah
    436
    Any other motor you drop in will need mount mods that I am aware of.
    Only difference between the 81/82 and 83/84 is the shifter shaft.
    HondaRidr's Avatar
    Salt Lake
    343
    Why do you want a different engine?
    Sent from my SM-G930T using Tapatalk
    Apr 2014
    Edmond, KS
    2,591
    It would be a little tough since they're right hand drive. Most are left hand drive.
    Apr 2017
    Thunder bay, ON
    19
    That is the one part I need, haven't been able to locate one.
    Apr 2017
    Thunder bay, ON
    19
    Quote Originally Posted by HondaRidr View Post
    Because trying to find parts for this thing has been a pain in the ass, would like to find a newer engine to slap in it with parts that aren't damn near impossible to find.
    It doesn't work that way. You'd have a much bigger project on your hands cramming the wrong engine in there than you would trying to source parts for the correct engine. If you're frustrated either calm down and make some connections in the community or send the bike along to someone with more patience. There's a lot of reasons why another engine is going to be difficult. General engine fitment for one, exhaust, intake clearance, and the lack of a counter balance if you use a bike engine.
    For the love or not at all.
    Apr 2017
    Thunder bay, ON
    19
    Thanks for your input, however I would like to stay on topic. I "love" custom jobs so I would like a list of modern right hand shaft engines please. Modifying the frame isn't out of the question.
    If you're the fabricator you're trying to portray yourself as then put whatever you want in there. I put a CR480 engine in my 84 ATC250R chassis.
    Apr 2017
    Thunder bay, ON
    19
    Not a machinist, but I have a 3 in one mig/stick/tig and can use it well enough to make the frame take a different shape. Thanks, I'll add the CR480 to my potential donors.
    Apr 2014
    Edmond, KS
    2,591
    If I remember, that isn't a drop in either. I also seem to recall that Fabio's 480 may stretch your arms a little if you ride it for very long. It's also not a newer engine. It was made in '82 and '83 if I recall. Honda used a lot of right hand drive engines inn the later 70's and early 80's. It may not be much easier to find parts for them either.
    devore,ca
    1,043
    No matter what you find, the kick start will be the wrong direction also.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
