Results 1 to 3 of 3
Thread: ATC 250r shifter shaft
    Apr 2017
    Thunder bay, ON
    19
    Looking for a shifter shaft for a 1983/1984, none on ebay.
    6,809
    If all else fails cut the bad end off and weld on a spline from another Honda model with the same spline count .
    I have done this many times and if done right you wouldn't even know
    Apr 2017
    Thunder bay, ON
    19
    It's not the spline that is broken, it's the gear inside. The machine shop can't machine new teeth on it because it's hardned steel
