83 Honda 200x
Just bought a new carb off eBay it's a pz30 wonder if that's the same carb as a pd62a if not what's different and should I jet it first before riding it does have full dg rcm exhaust on bike just bought it was sitting 10yrs reason I bought new carb for one the throttle cable was bad and for 2 the carb slide has big grooves in it. Starts right up first or second kick with old carb haven't ran it with new carb yet to late time wise to start it up please help should I put new throttle cable on old carb or try the new carb not sure if it's the right carb air cleaner hose doesn't fit on the carb. That side of carb is bigger any suggestions
Ahhhhhhhh, what? You answered your own question as to whether they are the same carbs. Different number and size is different. That was easy. Try running your old carb. How does it run? Fixing the stock parts is going to be better than the China junk most of the time.
//ArrowChat Integreation Code
