Results 1 to 15 of 16
Thread: 350x drive chain advice
    Lewiston, N.Y.
    1,479
    Time for me to replace my drive chain - does everyone have a favorite brand & model to recommend? Do I change sprockets or is that not needed?
    Sulphur Springs,Texas
    1,005
    D.I.D. Pro V Series Drive Chain O-Ring is a good option. If the sprockets are worn, I would replace and get it all new.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Lewiston, N.Y.
    1,479
    Do you know what size or model the 350x requires?
    I saw someone previously mentioned an x-ring?
    1,005
    520x90 is the size you need. O ring is what originally came on it.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    May 2009
    S.E. Michigan
    1,251
    Like Hondatcs mentioned above, factory used a regular o-ring chain. I wouldn't use anything less. Racers use non o-ring chains to avoid the drag (which can be noticeable) but chain life is sacrificed (no problem for a racer). An x-ring chain uses a special o-ring cross section (and x cross section) which provides two sealing surfaces rather than just one on a regular o-ring.
    I run an EK x-ring chain. You can find them on e-bay for 50-60ish. Note that you may not find exactly a 90 link chain, but if you see a good deal on a longer one, you can easily press out the rivets and remove the extra links and make it the length you need. Pay attention to the details of the chain as many of them are different colors (gold seems common). Not my thing, I run a natural color one, just as the factory chain was.
    I'd heard the rule that if you needed a chain, that you should replace sprockets at the same time. It is hard to tell just how worn they are. If they are really worn, it will be noticeable, but comparing to a new sprocket makes it a lot easier to determine how worn they are.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    I run Renthal R3's on everything. Steel sprockets too. Also like said replace everything. A worn chain on new sprockets will wear the sprockets faster and vice versa.
    2 in the back, 1 in the front.
    Lewiston, N.Y.
    1,479
    What's a good place for sprockets
    May 2009
    S.E. Michigan
    1,251
    E-bay. Search for Sunstar branded sprockets. I've been using them on my machines and they have been very durable.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Lewiston, N.Y.
    1,479
    Can someone please provide a direct link to a renthal r3-2 o ring chain with 90 links (as needed by the 350x). I have spent a considerable amount of time trying to find it and I have not been able to do so and quite frankly it's driving me nuts! Lol
    Slidell, LA
    4,738
    Lewiston, N.Y.
    1,479
    Hey Brandon! Thanks for the reply; unfortunately that chain is to big it seems only options are 116 & 120 link
    efhondakid's Avatar
    Feb 2015
    Canton Ohio
    203
    Your gonna have to cut it down. I have never bought a chain that went right on without having to take some links out.
    Lewiston, N.Y.
    1,479
    Forgive my ignorance but how do you remove links?
    efhondakid's Avatar
    Feb 2015
    Canton Ohio
    203
    YouTube my friend. YouTube.
    May 2009
    S.E. Michigan
    1,251
    Either a rivet press, or a grinder.
    The rivet press will push out the rivet holding two links together and does it in a non-damaging way. You can turn around and press the rivet back in and put the chain together.
    (just and example, not an endorsement of the product) --> http://www.motorcycle-superstore.com...-riveting-tool
    (or this one) --> https://www.harborfreight.com/heavy-...ker-66488.html
    Alternative is to grind the head off of one of the rivets and drive it out with a punch. No big deal if you know you don't need the extra links... and you have a clip style master link.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
