Results 1 to 7 of 7
Thread: TTR225 cylinder and head on YTM 225dx
    Apr 2017
    Tucson, Az
    42
    My 225dx needs the top end rebuilt. I found a good TTR225 top end for a good price. Does anyone know if it will fit/work? If it does is it a performance upgrade? I also found a new cylinder and piston from niche industries (part number 1509) as a stock replacement. https://www.amazon.com/Niche-Industr.../dp/B01LZL04TR. Has anyone heard of this company, I'm not finding many reviews on them. Or should I just bore and rebuild my current cylinder?
    Thank you in advance,
    Jake.
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    Just bore you're cylinder. I wouldn't use one of those Chinese kits. http://www.partzilla.com/parts/detai...110-01-00.html
    The TTR cylinder looks to have the same part Number.
    Jan 2017
    SD
    39
    yes you can use the ttr stuff and yes it raises compression from 8.8:1 to 9.5:1 and that is a performance upgrade. xt225 topends will also work
    Apr 2017
    Tucson, Az
    42
    Thank you guys you are awesome.
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    Wiseco also sells a 10:1 kit for the YTM225 if you want to pony up the extra cash.
    glendive, montana
    1,822
    the niche cylinders are actually pretty good just rebuilt a grizzly 660 with one and I am very pleased with it, only down fall is they dont soften the sharp edges and you can cut yourself on them.
    Mexico
    9,014
    Parts crossover is typically as easy as copy pasting the Yamaha part numbers from a fiche side by side on a spreadsheet. When I rebuilt my YTM I would paste discontinued part numbers from the fiche into Google search and many times the part number would come up for a newer vehical, or I would be directed to a site that still had stock.
