Thread: What's My Trike Worth?: 1983 YTM 225DX **PICS ATTACHED**
    May 2017
    Cleveland Ohio
    4
    I have a 1983 Yamaha tri moto 225DX that i was curious as to what the value of it could possibly be.
    As far as the condition of the bike its been torn down and every part cleaned and "restored" over the past couple weeks. New tires, new rear brake pad, recovered seat, rear carrier bearings, all fluids changed (oil, rear end), carb rebuilt, plug, new battery, new hardware. ONLY thing its missing is front brake lever and cable ( brake hub still functionable). Everything works on it ( E-start, rear brakes, headlight hi.low, tailight, choke, key ignition, kill-switch, suspension etc. Every bearing and bolt is tight on the bike. Starts right up with pull-start or Electric start. idles perfect after warm and is quiet. Doesn't burn any oil, no leaks. Has a real slight clutch slip on initial take off but shifts and holds power through every gear. plastics arent mint and has DR stickers on rear but isn't a DR, no cracks.
    Located in Cleveland Ohio area-- What could she be sold for $$$?
    Appreciate any input!
    Thanks!
    -Dylan
ID:	243323   Click image for larger version.
ID:	243324   Click image for larger version.
ID:	243318   Click image for larger version.
ID:	243319   Click image for larger version.
ID:	243322   Click image for larger version.
ID:	243321   Click image for larger version.
    May 2017
    Cleveland Ohio
    4
    *****Bump*****
    Jul 2017
    Antioch Il
    I saw one sell recently for 1,200, it was blue, don't remember the year....it needed a little work, headlight didn't work, and something else I don't recall what at the moment, but it didn't look as good as this one.
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    You could probably get $1000 for it if the person knows nothing about three wheelers. To someone who knows three wheelers id say it'd be hard to get $500. All original ones in good condition run about $1000. Most people here wouldn't want it because of how the restoration was done.
    It's worth whatever someone is willing to pay.
