Thread: 85 200X caliper piston doesn't go in
    Sep 2003
    17
    I followed the 1985 200X shop manual instructions on
    how to change the rear brake pads but the
    caliper piston won't go in, any ideas?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Did you try adjusting the parking brake screw? If not loosen up the nut and back the bolt off some to allow some clearence.
    Howdy
    nitekrawler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    430
    Re: 85 200X caliper piston doesn't go in
    Quote Originally Posted by atc1985
    Take the pressure out of the line (remove the brake fluid)
    1982 Honda Atc 250r - Daughter's
    1982 Honda Atc 250r - Son's
    http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
    Sep 2003
    17
    Thanks for the advice !!!
    I'll give it a try.
    Jul 2003
    430
    Leave the Banjo bolts off, then push the piston back
