Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Thread: Atc 70 xmas special replica
  1. #31
    Sep 2014
    Oregon
    591
    Looking good dude. Can’t wait to see it finished. I wouldn’t mind scrounging up one of those 70’s!
    Trikes owned:
    83 Honda 200x "Liquid X"
    81 DG 250r : Sold
  2. #32
    oldoo's Avatar
    oldoo is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2017
    Australia
    155
    Quote Originally Posted by x-rider View Post
    Cheers man, it’s getting there.
  3. #33
    oldoo's Avatar
    May 2017
    Australia
    155
    So I started mocking up an adapter plate for the rear caliper. I originally was going to use aluminium but I had steel plate laying around so I’m using steel.
    I will be machining some steel pins and welding them to the plate for the bolts to go through. More pics to come as I progress through it.
    P.S it’s handy to have a spare frame as seen in the pics.
  4. #34
    oldoo's Avatar
    May 2017
    Australia
    155
    Tonight I fitted my front fender and number plate.
    I’m really disappointed with the paint match between the tank and front fender.
    I followed advice of the PPG new sears blue and got it mixed up st my local PPG supplier. I’m guessing the guy didn’t mix it well? I don’t know a lot about paint go be honest.
    Anyway I cleaned up an original front number plate but I will be upgrading it to an aluminium one that I will be making at some point.
    I machined up some spacers to mount the fenders with based off the oem fender washers. I soon found out maier fenders are different so I’ll keep these aside for my next build where I’ll be using some used oem fenders.
    Here’s some update pics.
  5. #35
    oldoo's Avatar
    May 2017
    Australia
    155
    Tonight I welded the machined pins for the rear caliper setup. Slowly I’m getting this darn rear caliper mounting sorted.
  6. #36
    oldoo's Avatar
    May 2017
    Australia
    155
    Still kicking around with mounting this caliper. I either have to grind back the cr80 plate that the caliper bolts to or have to make my own to have enough clearance....
    I have although drilled a few extra holes to secure the plate better to the frame. Long bolts will go through the pins to attach caliper to frame securely.
    Hopefully my future builds don’t drag out like this one as I have learnt from this build.
    Cheers,
    Oldo
  7. #37
    oldoo's Avatar
    May 2017
    Australia
    155
    Alas, disc hub done
    Pitbike silencer arrived. Going to shorten it 50mm for better fittment.
    Yoshi Rep lol
    Stay tuned, more to come
  8. #38
    oldoo's Avatar
    May 2017
    Australia
    155
    Liking how it looks so far....
  9. #39
    oldoo's Avatar
    May 2017
    Australia
    155
    UPDATE TIME
    fenders on, exhaust made,
    Just need to fabricate up the intake manifold and a few other small bits.
    All in good time.
    Stay tuned 🤙🏼
  10. #40
    oldoo's Avatar
    May 2017
    Australia
    155
    Caliper mounted,
    In the process of machine up and welding an intake together.
    Got the rear sprocket hub vapourblasted.
    Lastly, I’m running a wr450 brake perch up front for the rear brake. I had my mate modify an atc 250r vaster cylinder guard to fit it. I reckon it’s a cool little touch to add to the build.
