Results 1 to 15 of 15
Thread: Banshee Reed Block in Tri-Z
    Arizona
    843
    I'm really impressed with the RAD valve on my 250R so I'm thinking about getting one for my Tri-Z. Did Boyesen ever made a RAD valve for the Z? Or, if not, does anyone know if the Banshee manifold will work with the Tri-Z. It looks like the Banshee has the same 4 bolt manifold but I'm not sure if it has the same dimensions. I know Boyesen makes a RAD valve for the Banshee, so I'm thinking it might work with the Z.
    Jan 2014
    Prescott az
    713
    I've seen them in the z before I think from a yz250 though
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Carthage NY 250r rules
    2,355
    X2 on the Rad valve Im running one on my 85 250r and it realy rips with the other bolt ons I have on it.
    250r rules
    Jan 2014
    Prescott az
    713
    I might be wrong on the yz250 block but the banshee and tri z part numbers are almost identical
    Banshee 2gu-13610-01-00
    Tri z 1rx-13610-01-00
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Arizona
    843
    The problem with the YZ is that it comes off the cylinder at an angle, like almost every motocross bike. The challenge is to find a RAD valve that comes straight back and has the right bolt pattern. The KX 125 (05-06) has the right bolt pattern but it comes off at an angle. I think the Yamaha WR 250 is the same. The Banshee comes straight back and has the 4 bolt pattern, but I'm just not sure about the dimensions. The part numbers for the gaskets aren't the same, so it doesn't look good.
    Jan 2014
    Prescott az
    713
    I thought you were just looking for the Reed block and not the boot.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Jan 2014
    Prescott az
    713
    Nevermind I mis read the post.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Arizona
    843
    The Boyesen RAD valve includes the reeds and the manifold--made of aluminum--so it has to be angled correctly.
    Jan 2014
    Prescott az
    713
    I might know someone with a banshee I can look at it
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Jan 2014
    Prescott az
    713
    Yeah banshees are more square while the z is rectangle.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Arizona
    843
    Quote Originally Posted by 6spdls1z28 View Post
    Thanks, that's what I was beginning to suspect. I'm going to continue to look into it. I may call Boyesen and see if they can help.
    Jan 2014
    Prescott az
    713
    Let me know what you find
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    2,355
    Check snowmobile reed blocks aswell.
    250r rules
    Jan 2014
    Massachusetts USA
    782
    http://www.partzilla.com/parts/detai...621-01-00.html
    This is the reed cage gasket, Partzilla shows all the yanahas that it fits. You'll have to do some research as to what has the same angle, but at least you'll know what nachines have the same bolt pattern.
    1985 Tri-Z 250
    1985 ATC250R
    Jan 2014
    Prescott az
    713
    Quote Originally Posted by christph View Post
    I have another Reed question. On an older post shows you running the v force in your z is this the 06 kx125 setup because the 89-96 yz250 vforce does fit in the z
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
