Results 1 to 3 of 3
Thread: Klt 160 front tire
    Jun 2017
    Lake Wales, Fl
    31
    Klt 160 front tire
    Has anyone tried to put a different size tire on the front of a kawasaki klt 160. Cheng Shin makes the only 21x9-8 tire and was wondering if a different size would fit.
    Apr 2014
    Edmond, KS
    2,591
    I'm not sure what size you're thinking of, but taller or shorter should work as long as you stay with about the same width. If you go wider, you could have trouble with it hitting your forks.
    Jun 2017
    Lake Wales, Fl
    31
    22x10 has a lot more choices. I am scared of it rubbing the forks. The 22x9 tire currently on it is only 8 inches wide inflated to 3lbs. I was hoping someone has tried a different size because not all brands run exact size.
