Results 1 to 15 of 21
Thread: 83 250r stalls when put in gear
    Apr 2016
    Manitoba
    60
    Runs and idles good but as soon as I let the clutch out the smallest bit in first it stalls, anyone got any suggestions?
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Do you have riding experience on other 2 strokes and this one is acting different? Not much info in your post but I would say give it more gas as you let out the clutch based on the info you provided.
    Apr 2016
    Manitoba
    60
    Quote Originally Posted by gimmeamidget View Post
    Doesn't matter if it's to the wood it'll still stall or just barely get going if I'm lucky
    Nov 2004
    Waterloo IL
    2,701
    Does the bike roll OK? Can you push it around?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Apr 2016
    Manitoba
    60
    Yup rolls good and once if it does get going goes through the gears good and runs right
    Nov 2004
    Waterloo IL
    2,701
    Have you tried to take off in second gear?
    Jun 2014
    utah
    436
    How do the reeds look?
    Jan 2014
    Massachusetts USA
    782
    1. Are you sure it's actually in first? If you're stuck in second that could be an issue.
    2. Has the gearing been changed? Does it have some tiny tear sprocket because the previous owner wanted it to be the fastest three wheeler in the world (even faster than a tecate)?
    3. Did some previous owner port the snots out of it, so it now has a powerband that starts pulling at 4500 and signs off at 4550, and doesn't have enough low end torque to pull the skin off of pudding? I had a cr125 Elsinore like that.
    These are just a few suggestions, trying to throw stuff out there others may not have thought of.
    1985 Tri-Z 250
    1985 ATC250R
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    It might help to check the compression as well...maybe its low and needs a top end.
    Mexico
    9,019
    Put it up on blocks, remove the spark plug, put it in gear and try to move the kick starter, or turn the rear wheels by hand and report back.
    Apr 2016
    Manitoba
    60
    The reeds are Brand new
    Apr 2016
    Manitoba
    60
    And the top end is fresh to, this problem seemed to get progressively worse when I first got it itd go no problem then occasionally it would stall or bog really bad when taking off now it's rare for it to go
    Apr 2016
    Manitoba
    60
    I bought the bike blown up needed the top end done so I got that done, reeds were a bit dodgy so got new ones, that's all the work that's been done to it and all very recent this problem started getting bad on my first ride that was actually a decent distance other than that just went up and down the road and this problem wasn't to bad, can't really think of any other useful information
    Mexico
    9,019
    Where are you in proximity to WPG?
    Apr 2016
    Manitoba
    60
    About 30 minutes north of the perimeter just past Selkirk
