Thread: '85 200X runs but won't start?
    Mar 2015
    Started fine pulling it out of the garage, took it to the trails and it wouldn't start coming off the trailer. Had a buddy give it a tug and it pop started fine and ran great all day, including kickstarting fine when I stalled it. Got a chance to clean the carb yesterday, same thing. Initial kick start nothing, had to be pulled to pop start it. Then ran fantastic. This is new as it has always started great cold, even in the middle of winter never more than 1-3 kicks. Stumped because once it is going, if it shuts off it will kick start, only does it when the engine is cold.
    Eric
    1985 Honda 200X
    2014 Arctic Cat 500
    2012 Honda trx250x
    2000 Suzuki LT160
    Sold and missed:
    1986 Honda 250sx
    1985 Big Red 250es
    2004 Dinli 90
    1989 Honda Foreman 350d
    2002 AC 500
    1999 AC 500
    2001 Rancher 350
    1984 Odyssey fl250
    2015 Kawasaki KFX90
    2005 LT80
    1985 Honda TRX125 (3)
    2004.5 Sportsman 500HO (2)
    2005 Scrambler 500HO
    2002 Scrambler 500HO
    6,811
    Time for a complete service , carburetor, valve adjustment , compression check , visual spark check . These motors can be difficult to start unless every thing is just right .
    Mar 2015
    Valves adjusted, carb has been cleaned. Runs fantastic once started, idles fine as well. Now however it is getting hard to kick even when warm? What are the carb settings stock? I adjusted them to where they were when I cleaned it however, I'm not sure that the prior owner didn't have that messed up.
    Eric
    1985 Honda 200X
    2014 Arctic Cat 500
    2012 Honda trx250x
    2000 Suzuki LT160
    Sold and missed:
    1986 Honda 250sx
    1985 Big Red 250es
    2004 Dinli 90
    2002 AC 500
    1999 AC 500
    2001 Rancher 350
    1984 Odyssey fl250
    2015 Kawasaki KFX90
    2005 LT80
    6,811
    Air fuel screw is set at a low idle , turn it in until it starts to run rough and then turn it out until it starts to run rough , find the middle between the two which also should be the best at idle . Usually between 1 and 2 1/2 turns out .
