Thread: 225dx help
    kap is offline First Time Rider Arm chair racerNew to the board
    Dec 2003
    86
    225dx help
    hey
    i gotta 225dx and the carb leaks all the time ive replced the carb and then bought a kit for it and it wont stop leaking
    Washingtons Crossing, Pa.
    2,977
    Whats leaking? .... I'm assuming its coming out of the bowl overflow - which in that case, you need to either replace the needle valve or remove whatever is keeping it from seating properly (ie dirt, rust, varnish).
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    If it is leaking air, through the carb, there is a tiny screw that can come loose ,on the carb,which allows air to get by if it is loose or missing.On my 2 dx's the screws do not serve much purpose other than plugging the hole.So try to tighten it if it is loose.
    Dec 2003
    86
    yea
    its leakin there and in te drain screw
