Thread: Need help with 200x rebuild
    Aug 2014
    Seattle,wa
    3
    Hey been a member for a bit and followed here and there over few years but never posted. I have a project I a gonna start but need help. The motor of choice is a 200x and I just picked up a 84 200x more or less basket case. Guy swears it's all there in 2 buckets and I got frame with bits. Only thing missing is carb and handle bar controls. He said and pointed to the spun bearing. It's the connecting rod/crank bearing. Cylinder looks good. Haven't got a chance to go through all the bits and don't really wanna split case before knowing more info. Thought on rebuild kit or should I just focus on the beating and address what's there as I find more? I can't find rebuild kits or even the solo bearing. I have money but I'm also married so I kinda don't. I don't want a power house, just get it back to running. Is there a better/cheaper easier to find carb than the 200x? Like xr, xl, 200s carb? I have a 85 250sx that runs great with a cobra exhaust if any someplace stiff from that can help to run the 200. Like carb and missing electronics. Just so I know it runs fine then buy the parts it needs. Manuals also seem hard to find. Tons of 86+ manuals.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    I think all 200's (except maybe the 200es) have the same rod bearing, so just keep an eye out on ebay. xr200 carbs fit and ad a little power 200s carbs will let it run but not well. I don't think any 250sx parts will work since they are completely different machines.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Aug 2014
    Seattle,wa
    3
    Yea I knew the top of ends swapped nicely. 185,200 that is. Carb seemed hard to find stock and not Chinese for 200x so maybe I try to find xr200 one. I just didn't know if they changed in size so I should stick to certain year range beside the 84-85 dual thing. This entire project is for a 1990 cr80 that had bad bearing and needed rebuild so I picked it up cheap. I'm a trail rider and an adult. But a 200 4 stroke in a cr80 with 10" front and back travel at hopefully 175lbs sounds like a fun toy.
    Apr 2017
    McConnelsville,Oh
    157
    Sure does sound like it will be fun. Good luck with the project!
    1985 ATC125M: Parts
    1988 TRX250X
    Aug 2014
    Seattle,wa
    3
    Can a xr200 crank fit or are they diff?. I read stroke is different in books but I also read those books are wrong.
    Apr 2017
    McConnelsville,Oh
    157
    I'm not sure I believe they are both 192cc and they both have 65mm pistons so they most likely have the same stroke but it may just be certain years of the xr
    1985 ATC125M: Parts
    1988 TRX250X
